AutoCAD Forum
Layer Properties Manager
3 REPLIES 3
zeusqui
571 Views, 3 Replies
Running AutoCAD 2007 on Vista. Suddenly, clicking on layers property manager or typing Layer on command line results in a fatal exception and AutoCAD is forced to close. Help?
3 REPLIES 3
pendean
in reply to: zeusqui
Roll back Windows to a month or year everything worked and see if that helps.
And unplug anything you recently plugged into your PC.
zeusqui
in reply to: pendean
Thank-you pendean. After literally 10 hours of attempting to restore Windows to a previous point only to have that be unsuccessful, un-installing updates one at a time, rebooting maybe 15 times, and reading the forums, I found one comment to try as a last resort. I added the autocad.exe program file to the Vista windows exceptions to the Windows firewall. I can now click on the layer properties manager and the window opens. I am even able to add new layers! I feel like such a clutz and dizzy from getting beat-up by Windows. I expect it was the malicious removal tool update that might have caused the issue in the first place. Thank-you for your incredibly prompt response! It does the heart good to know that you had an interest in my dilemma.
dtcsurveys.dennis
I am having the same problem.  Running 2007 on Windows 7 professional.  I have tried adding acad.exe to the windows firewall allowed programs with no luck.  Any help would be appreciated.
”Boost
