AutoCAD 2007/2008/2009
Valued Contributor
jonjon107
Message 1 of 6 (116 Views)
Layer Lisp Color Book Trouble
116 Views, 5 Replies
08-02-2006 08:02 AM
I have a lisp routine that makes all of the standard layers for a division of my company. it used to work well until now. i have added some "colorbook" colors to the new layers and when the lisp routine gets to that part it gives an error, stops and asks for "Truecolor/COlorbook". how do i get it to automatically make the color and continue? the following are a "good string" (one with a normal color that works and a "bad one" (the one with the colorbook color that doesn't work)
good - (blayer "ACID WASTE - TEXT" "7" "continuous" "default" "p")
bad - (blayer "BOILER FEED WATER" "DIC 161" "continuous" "default" "p")
also i have inserted the lisp that the previous one uses.
(defun blayer (name color ltype lwgt plot)
(if (tblsearch "LAYER" name) ;If NAME exists
(command "_.LAYER" "_S" name "") ;then set it current
(progn ;Otherwise...
(setq regen (getvar "REGENMODE"))
(setvar "REGENMODE" 0)
(command "_.LAYER" "_M" name) ;Create & set it current
(if color (command "_C" color name)) ;Set color if specified
(if ltype (command "_LT" ltype name)) ;Set ltype if specified
(if lwgt (command "_LW" lwgt name)) ;Set lwght if specified
(if plot (command "_P" plot name)) ;set plot if specified
(command "") ;End layer command
(setvar "REGENMODE" regen)
);progn
);if
(princ)
);defun
any help with this would be greatly appreciated
*A+P
Message 2 of 6 (116 Views)
Re: Layer Lisp Color Book Trouble
08-02-2006 09:45 AM in reply to: jonjon107
When it comes to assigning color book colors to layers, you have to add some
additional parameters. Just follow the command line prompts by
typing -LAYER (command is preceded with a hyphen).
After you enter _C, you have to enter a _Col to tell AutoCAD you want to
specify a Colorbook. Then enter the color book name. In your case the name
is DIC COLOR GUIDE(R).
Then you enter "DIC 161"
Paul
wrote in message news:5256252@discussion.autodesk.com...
);progn
);if
(princ)
);defun
Valued Contributor
jonjon107
Message 3 of 6 (116 Views)
08-02-2006 10:54 AM in reply to: jonjon107
I still don't completely understand. i'm not well versed in lisp.
*A+P
Message 4 of 6 (116 Views)
08-02-2006 01:31 PM in reply to: jonjon107
As a quick answer to your lisp request, below is a revised function called
blayerc which only works when you want to specify colorbook
colors...enjoy....
(blayerc "BOILER FEED WATER" "DIC COLOR GUIDE(R)" "DIC 161" "continuous"
"default" "p")
(defun blayerc (name colorbook color ltype lwgt plot)
(if color (command "_C" "_Col" colorbook color name)) ;Set color if
specified
);progn
);if
(princ)
);defun
wrote in message news:5256622@discussion.autodesk.com...
Valued Contributor
jonjon107
Message 5 of 6 (116 Views)
08-03-2006 06:23 AM in reply to: jonjon107
So this won't work for layers with both color books and standard autocad colors?
*A+P
Message 6 of 6 (116 Views)
08-03-2006 09:06 AM in reply to: jonjon107
No.
Paul
wrote in message news:5257604@discussion.autodesk.com...
colors?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
