AutoCAD 2007/2008/2009
0 Kudos
Post 1 of 4
.JP2 files
680 Views, 3 Replies
01-04-2012 09:00 AM
I am attempting to attach an image file (.jp2) to my drawing.  I am completely successful at getting the image attached, inserted, scaled correctly, etc.  However, I am only seeing a small part of the image.  Please see the attachment for a screen shot.  Does anyone know what's going on here and (preferably) how to fix it?  The original image is not clipped like this.  I did not use IMAGECLIP.  The screen shot was taken immediately after attaching the image to the drawing.
Thanks!!
1,596 Kudos
Post 2 of 4
Re: .JP2 files
01-04-2012 02:26 PM in reply to: rubaru
Try posting in the CIVIL forum (matches your AutoCAD version).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
0 Kudos
Post 3 of 4
Re: .JP2 files
07-30-2012 08:28 AM in reply to: rubaru
i am having a similiar problem with .jp2 files in ACAD 2008
The files go in, both as XRef and as insert; can set coordinates and scale OK
Only the top 1/2 of the image shows; the bottom 1/2 is blacked out
same result with multiple images
Images go into ArcView Ok
any help will be appreciated
thnx
jwalker2
127 Kudos
Post 4 of 4
Re: .JP2 files
08-01-2012 10:27 PM in reply to: jwalker2
The first thing that comes to my mind when I see this is that it may be related to video memory.  For some reason your system(s) are choking on the size of the image file.
As a test, and if you have software like GIMP, Photoshop, Elements, etc that can reduce the resolution and therefore the size of the image file, reduce it, save to a new filename, and try again.  If it's 600dpi, downsize and resave it as a 120 dpi file and repeat the insert.
If it works with a smaller file then you've confirmed a video card issue.
Dave.
Dave Hein, P.E.
