AutoCAD 2007/2008/2009
Valued Contributor
cypress999
Message 1 of 14 (4,051 Views)
Inserting a multi page word doc as an ole object
4051 Views, 13 Replies
08-18-2010 11:51 AM
Hi everyone,
I am having trouble inserting a multi page word doc into my autocad drawing, for some reason the first page only shows up, is there a way to make all the pages show up?
pendean
Message 2 of 14 (4,040 Views)
Re: Inserting a multi page word doc as an ole object
08-18-2010 02:03 PM in reply to: cypress999
OLE has a one page limit.
To get beyond the limit, you need to BUY a third party solution like that offered at dotsoft.com
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
kylenelson3113
Message 3 of 14 (4,035 Views)
08-18-2010 02:43 PM in reply to: cypress999
The way we do it is save the document as a rich text format (rtf) in word. Then in Autocad run the MTEXT command.  Specify an area that the document will fit into then the mtext editor becomes active.
While in the MTEXT editor right click and select "import text".  Browse to the "rtf" file you created and it will insert it.  You can make it multiple columns and all your formatting should be the same as in word.
pendean
Message 4 of 14 (4,007 Views)
08-19-2010 05:30 AM in reply to: kylenelson3113
An excellent workaround if the OP does not need OLE linking, the reason to use OLE, otherwise copy/paste from inside MSWord to inside MTEXT window is even quicker than the RTF route.
New Member
taramitchell3
Message 5 of 14 (3,538 Views)
09-08-2011 09:10 AM in reply to: cypress999
Solution!
In Microsoft Word, select the whole first page, then edit-->copy.
Then in AutoCAD, go to edit-->Paste Special
Under the Paste Special dialog box, be sure to check the "Paste Link" option and that Microsoft Word Document is highlighted.  Click OK, then insert where desired!
You will have to repeat the process for the second page, third page, and so on--- but it is now an OLE Object and when edited it will update automatically.
Active Contributor
PDSF
Message 6 of 14 (3,231 Views)
04-11-2012 05:22 PM in reply to: taramitchell3
I Googled for an answer to this issue and found this thread.  Taramitchell's idea sounds great, but unfortunately doesn't work for me because the Word document I am referencing has many style-based indents and numberings (like for specs), and for some reason rather than showing up as they are in the .doc, they reset to 1, a, i etc. on every newly linked page (see attachment).  Bummer :smileysad: If anyone knows a (free) method which would preserve the indent numberings I would be extremely grateful.  Otherwise I may have to purchase the product mentioned above, as updating for modifications page-by-page would be extremely tedious.
New Member
cland
Message 7 of 14 (2,579 Views)
03-04-2013 01:35 PM in reply to: PDSF
PDSF,
I have the same issue. It is specs froma word document with numbering and it is screwing up the numbering. Did you ever find a solution? I don't want to have to type 15 pages of specs.
Active Contributor
PDSF
Message 8 of 14 (2,573 Views)
03-04-2013 02:29 PM in reply to: cland
I didn't, sorry.  We did the extremely primitive method of exporting to .jpg and linking those.  We had to re-export a few times over the life of the project.  If anyone has a better solution I'd still be interested.
pendean
Message 9 of 14 (2,563 Views)
03-05-2013 05:48 AM in reply to: cland
OLE has a one-page limit: if you need OLE, buy an add-on like the one from dotsoft.com
If you don't need OLE, for pete's sake don't do the JPG method outlined above, just copy/paste from MSWord to an open MTEXT object and a few other options noted above your post. No one has had to retype text in since we all got out fo the DOS dark ages.
Active Contributor
PDSF
Message 10 of 14 (2,559 Views)
03-05-2013 09:10 AM in reply to: pendean
Even if that worked from a formatting standpoint, it doesn't work across multiple sheets.  We are talking about sizable Word documents here with complex formatting.  It takes 3 - 30x42 sheets to contain it all.
