AutoCAD 2007/2008/2009
Member
0 Kudos
Post 1 of 5
insert image
456 Views, 4 Replies
09-22-2012 02:22 AM
Hello my friends
I have a question about inserting images. Suppose we insert an image in AutoCAD , If we want to give this file to someone else, we have to put the image near the autocad file and give both of them !
but, when we insert an image in word, powerpoint, exel and ... No need to share this image again !
Is there any way that my images save in AutoCAD like Office ?
:catvery-happy:
you can, open the image in any software, mark an area, use function "copy". Change the focus to AutoCAD/to your drawing and then use "paste" to insert the image as OLE-object.
But don't wonder then that the size of the DWG-file raises up (and may be the quality of printing is not as good as a referenced version of the image).
To use _ETRANSMIT (a command that packs the DWG and the referenced files to a ZIP) would be the preferred method for transferring data to anyone else.
- alfred -
1,219 Kudos
Post 2 of 5
Re: insert image
09-22-2012 07:00 AM in reply to: daria_davar
- alfred -
Alfred NESWADBA
67 Kudos
Post 3 of 5
Re: insert image
09-24-2012 02:56 PM in reply to: daria_davar
Another method I have seen (but to this day have not figured out how he did it)
is to insert an image into a DWG file, then insert that DWG file into the current
DWG file as an unexploded block. I never did investigate if it was OLE... or not.
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
Distinguished Mentor
85 Kudos
Post 4 of 5
Re: insert image
09-24-2012 05:27 PM in reply to: scot-65
Something like this attachment, created with the Image Bind tool in ToolPac.
Member
0 Kudos
Post 5 of 5
Re: insert image
10-07-2012 10:42 PM in reply to: Alfred.NESWADBA
thank you very much for your reply and solution
:catvery-happy:
