AutoCAD 2007/2008/2009
Active Member
ayupyabugga
Message 1 of 22 (7,690 Views)
insert a PDF file to a drawing
7690 Views, 21 Replies
03-17-2008 03:34 AM
i am trying to insert a PDF file which contains a plan into a drawing, but am failing miserably. i go to the insertobj command and then am told "failed to create object. make sure the object is entered into the system registry".
can anybody, please, point me in the right direction if it s at all possible.
*Jimmy Bergmark
Message 2 of 22 (7,689 Views)
Re: insert a PDF file to a drawing
03-17-2008 04:30 AM in reply to: ayupyabugga
You probably need to repair your Adobe Reader or Acrobat.
Or you can print the PDF to DWF and the attach the DWF.
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"ayupyabugga" skrev i meddelandet news:5877315@discussion.autodesk.com...
> registry".
> possible.
*Dean Saadallah
Message 3 of 22 (7,689 Views)
03-17-2008 05:32 AM in reply to: ayupyabugga
Open the PDF in Acrobat Reader.
Click on the camera button, and window the area you want (zoom in for better
resolution capture, real close, the entire window will move when you hit the
edge of the screen. When done, Acrobat Reader will notify you it copied.
In AutoCAD, PASTESPEC, pick one of the image options.
Done.
A better solution: grab Autodesk's free DWF Windows driver, install it,
print your PDF to DWF, attach the DWF to your DWG file.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Distinguished Mentor
lpseifert
Message 4 of 22 (7,689 Views)
03-17-2008 06:39 AM in reply to: ayupyabugga
Do you have a link to download the driver that you mentioned?
Thanks-
~~~Civil 3D 2008~~~
*Allen Jessup
Message 5 of 22 (7,689 Views)
03-17-2008 08:47 AM in reply to: ayupyabugga
A 30 second search on the AutoDesk web site yields this:
http://usa.autodesk.com/adsk/servlet/index?id=8683923&siteID=123112
wrote in message news:5877440@discussion.autodesk.com...
Thanks-
lpseifert
Message 6 of 22 (7,689 Views)
03-17-2008 09:00 AM in reply to: ayupyabugga
I had searched, and found the one you pointed me to, and a driver for DWFx, and I didn't know which was appropriate; that's why I asked.
~~~Civil 3D 2008~~~
*Jimmy Bergmark
Message 7 of 22 (7,689 Views)
03-17-2008 10:36 AM in reply to: ayupyabugga
Go for the DWF one.
Jimmy Bergmark
Owner/Developer
AutoCAD 2009
"lpseifert" skrev i meddelandet news:5877673@discussion.autodesk.com...
lpseifert
Message 8 of 22 (7,689 Views)
03-17-2008 10:57 AM in reply to: ayupyabugga
Thank you-
~~~Civil 3D 2008~~~
*3DCad
Message 9 of 22 (7,689 Views)
03-19-2008 11:19 AM in reply to: ayupyabugga
Dean,
I've installed the DWF writer, (can produce windows based DWF),
"dwfattach" into DWG Drawing, all looks good, but this DWF file is an Xref,
XREF are NOT recommended in my case.
How can I insert or bind ---permanently attached to the drawing?
3dCAD
"Dean Saadallah" wrote in message
news:5877368@discussion.autodesk.com...
Done.
Dean Saadallah
Distinguished Contributor
ladonna101
Message 10 of 22 (7,689 Views)
03-19-2008 01:15 PM in reply to: ayupyabugga
Type CLASSICXREF select the Xref you want to bind and hit the BIND button.
Announcements
Need installation help?
