AutoCAD 2007/2008/2009
Distinguished Contributor
andrew_nao
Message 1 of 4 (426 Views)
import template settings into an existing dwg
426 Views, 3 Replies
03-26-2008 08:50 AM
I know from using acad mechanical 06, to import settings from your dwg
template the command was
amsetupdwg
can anyone tell me what the command for doing this in plain acad 08 is?
mwgrutter
Message 2 of 4 (426 Views)
Re: import template settings into an existing dwg
03-26-2008 10:39 AM in reply to: andrew_nao
Open your template file (.dwt) and save_as to a drawing file (.dwg) in the same folder. Use the INSERT command with the EXPLODE checkbox checked to bring your template settings into your current drawing. Just like importing any other setting or object, this will only add to the exiting, it will not change settings that are already there.
If you need to change settings that way you could create lists of system variables and their default settings and apply them using Lisp or create a standards file (.dws) from your template and use the Cad Standards Utilities to make the changes.
Michael Grutter
Cedar Engineering and Design Service
http://www.cedarengineering.com
2D Drafting, 3D Modeling, Legacy Conversion
andrew_nao
Message 3 of 4 (426 Views)
03-26-2008 12:00 PM in reply to: andrew_nao
if that were the case i would just copy the dwg and paste it into a
template.
thanks but thats not what i want to do
i remember seeing a command that took the settings from a template file and
imported them into an existing dwg
i did it once but i dont remember the command
wrote in message news:5886190@discussion.autodesk.com...
Michael Grutter
mwgrutter
Message 4 of 4 (426 Views)
03-26-2008 07:42 PM in reply to: andrew_nao
More than likely then, it was a third party app, Lisp routine or script that was defined as a command. Vanilla OOTB doesn't have many of the functions that vertical users have come to expect.
Michael Grutter
2D Drafting, 3D Modeling & Legacy Conversion
Announcements
Need installation help?
