AutoCAD 2007/2008/2009
Member
asiababe
Message 1 of 5 (325 Views)
I NEED HELP
325 Views, 4 Replies
11-09-2008 06:54 AM
When I start my AutoCad I get the error: Customization file load failed. File not found:
c:\users\nastja\appdata\roaming\adobe\acrobat\8.0\acad-5001-409\pdfic.cui
After this error AutoCAD starts but there are no toolbars except the Acrobat one
*A+P
Message 2 of 5 (325 Views)
Re: I NEED HELP
11-09-2008 01:23 PM in reply to: asiababe
Type Menuload
Then select the Acrobat menu and unload
that
Then Browse to your profile folder and locate the
AutoCAD acad.cui menu file:
"C:\Documents and
Settings\your-login-name\Application Data\Autodesk\AutoCAD
2007\R17.0\enu\support\acad"
Paul
When
found:
one
Member
asiababe
Message 3 of 5 (325 Views)
Re: I NEED HELP
11-10-2008 01:57 AM in reply to: asiababe
thanks, it worked.
am i able to find some info in internet about how different things in autocad works?
also, now, i cant use my keyboard for commands undo (ctrl+Z) - it was possible before..
*A+P
Message 4 of 5 (325 Views)
Re: I NEED HELP
11-10-2008 09:17 AM in reply to: asiababe
Do the following in AutoCAD 2007:
1. CUI
2. On the top let drop down list, select Main CUI
File (acad.cui)
3. Under Command List, select on the drop down list
Edit
4. Select Keyboard Shortcuts from the
Customizations inMain CUI window
5. Read the directions under the Information window on how to customize a
Keyboard Shortcuts
Paul
thanks,
it worked. am i able to find some info in internet about how different things
in autocad works? also, now, i cant use my keyboard for commands undo (ctrl+Z)
Member
asiababe
Message 5 of 5 (325 Views)
Re: I NEED HELP
11-14-2008 03:19 PM in reply to: asiababe
well. hello again.
i tried. but it doesnt work.
i still cant use double click to enter the text (for example).
and, then i click the rightmouse button, nthing happens. and before the was a list of commands like move.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
