HI. I HAVE A PROBLEM WITH AUTOCAD.
I HAVE AUTOCAD 2007. I CAN' T DO FROM TOOLBAL "FILE - OPEN" OR "FILE SAVE AS" BUT I CAN OPEN THE DRAWING WITH BOUBLE CLICK IN THE ICON
Solved by steve216586. Go to Solution.
Are you not getting a dialog box in which to choose the file? If this is the case check your FILEDIA setting. Change to 1 for it to appear.
