AutoCAD Forum
I CAN'T DO FILE - OPEN
4 REPLIES 4
panagiotazaf
311 Views, 4 Replies
HI. I HAVE A PROBLEM WITH AUTOCAD.
I HAVE AUTOCAD 2007. I CAN' T DO FROM TOOLBAL "FILE - OPEN" OR "FILE SAVE AS" BUT I CAN OPEN THE DRAWING WITH BOUBLE CLICK IN THE ICON
4 REPLIES 4
pendean
in reply to: panagiotazaf
Exdplain more please: so what happens exactly that is different?
steve216586
Are you not getting a dialog box in which to choose the file? If this is the case check your FILEDIA setting. Change to 1 for it to appear.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
panagiotazaf
in reply to: pendean
WHEN I DO "FILE - OPEN" IT DOESN'T OPEN THE DRAWING BUT THE COMMAND LINE
SAYS" ENTER NAME OF DRAWING TO OPEN". BEFORE THAT PROBLEM, I AM ALLWAYS
OPENING THE DRAWING FROM FILE - OPEN.
THE SAME PROBLEM I HAVE WHEN I DO "FILE - NEW" IT SAYS "ENTER TEMPLATE FILE
NAME" AND WHEN I DO "FILE - SAVE AS" IT SAYS "ENTER FILE FORMAT".
I DON' T WANT TO WORK FROM COMMAND LINE, BUT FROM THE TOOLBAR "FILE"
panagiotazaf
in reply to: steve216586
Thank you very much. I wrote in the command line filedia and then 1 and it
works.
”Boost
