How to Make a 3D table with AutoCAD
Introduction
www.Blog-Autocad3DTutorial.Blogspot.com - In making a 3D object, it would be better if you have a 2D files as in this previous article I made a 2D drawing table first. In making the 3D model is a model that must be controlled or the UCS coordinate system x, y and z, Why? in order to facilitate you in the process in accordance with the object you want. In the article here I will discuss about How to Make a 3D table with AutoCAD 2007.
Result Image 3D Table in AutoCAD:
Step-by-Step
Before trying to make this a 3D table, prepare a 2D table files (See here about creating a table 2D)
Steps to make the 3D table:
1. Open the image file table 2D
2. Set to display 3D via the menu View - 3D view - SW Isometric
3. Move object one by one so you can easily copy objects in the drawing and are required in addition to the image
4. Joint object that is not covered by a solid using PEDIT:
- The box model of the letter U for legs
5. Extrude object:
- The table legs and a triangular cross section
- Glass bottom
- Glass top
- A circle that is used to pierce the foot of the table
6. Rotate all objects in accordance with the position of the table leg
7. Subtract 7 foot as a cutting table which is circular
8. Create a circle within a circle with radius 2 and radius 3
9. Subtract the pipe with a pipe cutter inside
10.Extrude circle outermost parts with high 1
11.Adjust penompang glass pipe bottom and the top
12.Copy to the foot of the table to the right
13. Move the glass bottom and the top of the pipe to the top of the table
14. You can add the fillets on the side of the object to make it look smooth
If there is spare time I'll make a Video Tutorial of this article. That's How to Make a 3D Table With AutoCAD, AutoCAD 3D Tutorial Hopefully this article useful to readers who want to learn AutoCAD 3D, especially for beginners
Introduction
Image file 2D Table in AutoCAD :
Step-by-Step
5. Extrude object:
- Glass bottom
- Glass top
Result Render :
If there is spare time I'll make a video tutorial of this article. That's How to Make a 3D Table With AutoCAD, AutoCAD 3D Tutorial Hopefully this article useful to readers who want to learn AutoCAD 3D, especially for beginners. here's some other articles autocad 3d tutorials.
Why the link of the videos or the tutorial on YouTube is restricted or cannot view.
