AutoCAD 2007/2008/2009
New Member
auto333
Message 1 of 6 (1,777 Views)
HOW TO FLATTEN OR BRING ALL THE LINES IN 2D DRAWING TO 0,0 COORDINATE
1777 Views, 5 Replies
05-10-2009 05:57 PM
GUYS IS THERE A WAY OR COMMAND TO FLATTEN THE 2D AUTOCAD DRAWING TO 0,0 COORDINATE. FLATTEN COMMAND SOME HOW IS NOT DOING THAT. I EVEN TRIEND TO MANUALLY BRING ALL THE LINES TO 0,0. THEY SHOW THAT THEY ARE AT 0,0 WHEN YOU ID THEM BUT WHEN I TRY TO FILLET THEM THEY GAVE A ERROR MESSAGE SAYING LINES ARE NON COOPLANER.
WHILE MANULLY BRINGING THE LINES TO 0,0 I EVEN INCREASED THE PRECISION IN UNITS COMMAND TO MAXIMUM I.E 1/256. I AM USING AUTOCAD 2007.
YOUR HELP WILL BE HIGHLY APPRECIATED AS I AM TOTALLY CONFUSED NOW AND HAVE NO CLUE WHAT ELSE TO TO.
Distinguished Contributor
mixtup
Message 2 of 6 (1,777 Views)
Re: HOW TO FLATTEN OR BRING ALL THE LINES IN 2D DRAWING TO 0,0 COORDINATE
05-10-2009 06:18 PM in reply to: auto333
The error suggests that it's not the 0,0 (X,Y) that is causing the problem but that the lines you are trying to fillet have different Z values. You can check this in the properties box.
Tip: In the lower right hand side of screen you should see a padlock icon which is the Z-lock. Activating it will limit your work to Z=0.
*Dean Saadallah
Message 3 of 6 (1,777 Views)
05-11-2009 05:48 AM in reply to: auto333
rotate your UCS to look at your entities from one side, zoom in, measure to
Z=0 and see for yourself.
Dean Saadallah
http://LTisACAD.blogspot.com
Active Member
annie1706
Message 4 of 6 (1,777 Views)
05-11-2009 06:28 AM in reply to: auto333
Try this
Select the entire drawing--go to properties--list will show the no of lines-select lines- Geometry- change start z & end z to 0.
i have tried this with 2006. should work. Other problem is - any entity which is not a line will still be non co-planer. U wil need to find it & use the same procedure.
Valued Contributor
tom_kelly
Message 5 of 6 (1,777 Views)
05-17-2009 05:18 AM in reply to: auto333
One way is already mentioned that select all objects make Z- elevation "0" i.e if Lines --start and end elevation and if polyline then elevation = "0"
Second way is export drawing to DXF so that everything flattens out automatically.
Try this
Tom
www.indovance.com
New Member
GabbayArchitects
Message 6 of 6 (1,223 Views)
11-14-2012 04:36 PM in reply to: auto333
Hello Guys,
I am trying to flatten the file and nothing seems to work. I have tried flatten command, exporting as dxf, the only thing that works is selecting line by line and changing the z value. There has to be a faster way please help!!
Announcements
Need installation help?
