AutoCAD 2007/2008/2009
Member
jgranite
Message 1 of 10 (7,463 Views)
How to find the coordinate system of a drawing
7463 Views, 9 Replies
10-14-2010 12:11 PM
How do I find the coordinate system of a drawing? We frequently don't have access to the engineer/whomever created a drawing, so can't go that route, but need to know the coordinate system for converting into GIS. I have access to both ACAD and Civil 3D, if that makes a difference.  Thanks!
Active Contributor
chrisfreeman
Message 2 of 10 (7,418 Views)
Re: How to find the coordinate system of a drawing
10-15-2010 03:10 AM in reply to: jgranite
i have no idea!
 but this may help, type in "geographiclocation" on the command line
Member
jgranite
Message 3 of 10 (7,376 Views)
10-18-2010 10:02 AM in reply to: jgranite
Thanks for the response. "Geographiclocation" is literally the location of the area represented in the drawing -- lat/long, time zone. Unfortunately, it has nothing about the projection or coordinate system of the drawing.
I appreciate your thought, though.
Distinguished Contributor
TherealJD
Message 4 of 10 (7,334 Views)
10-19-2010 01:55 PM in reply to: jgranite
In civil 3D, go to toolspace and settings tab for the current drawing.. you can right-click on the dwg and get the info through there.. see attached picture for clarification..
norburydesign
Message 5 of 10 (7,282 Views)
10-30-2010 01:58 PM in reply to: jgranite
Are you looking to see how to see where the 0,0 origin is in the drawing?
If so you can draw a circle with an origin at 0,0 to see where the location is.
HTH
James
www.norburydesign.com
*Pro
Modman_4
Message 6 of 10 (7,276 Views)
11-01-2010 06:18 AM in reply to: norburydesign
Or draw a line from where you can see, to 0,0 in some color that stands out -- the ZE
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
*Expert Elite*
Icemanau
Message 7 of 10 (7,263 Views)
11-01-2010 03:45 PM in reply to: jgranite
Try going to Format -> Units.
you have a few choices in the Angle drop down box. Are these what you are looking for? The active one is the one displayed in the Drop Box
Decimal Degrees
Degrees/Minutes/Seconds
Grads
Radians
Surveyor Units.
There are a few other options in the dialogue box as well.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Member
jgranite
Message 8 of 10 (7,260 Views)
11-01-2010 04:01 PM in reply to: jgranite
Thanks for the responses. The coordinate system I'm referring to is the projection -- was the drawing created in UMT, State Plane, etc, etc.
TherealJD
Message 9 of 10 (7,241 Views)
11-03-2010 06:18 AM in reply to: jgranite
did you check my previous post about using Civil 3D? UTM info is located under the "zones" section in the drawing's settings... If your drawing was generated using info, that should have something showing there...
Member
jgranite
Message 10 of 10 (7,213 Views)
11-05-2010 11:44 AM in reply to: jgranite
I did -- thank you!  I was hoping there was a way within standard AutoCAD as well -- I generally use "AutoCAD Civil 3D as AutoCAD 2010", so helpful to not have to open/close multiple versions.  But I'll take what I can get....
Announcements
Need installation help?
