How to create a sink in AutoCAD 2007
I will share about how to make the sink using AutoCAD 2007 software before I've discussed how to make a house 2D, Autocad basics.
Step-by-Step:
1 Run Autocad 2007 or other versions may also
2 Set the unit of measurement to cm from the Format menu select Unit
2 Adjust the image area of 50 x 40 with orders Limits
3 Set the grid distance is 5 by typing the command Grid
4 Make the box with the Rectangle command with the size of X = 50 and Y = 40
5. Type FILLET command with a distance = 10 to make the tapered upper corners curved
6 Type the FILLET command with a distance = 15 to create curved corners tapered bottom
7 Create the middle vertical line box
8 Type the offset or click the button and type the offset distance is 5
9 Make circle in the middle of the line with a radius of 1.5 and 2
10 Type the Trim command to cut the line
11.Ubah display mode to 3D
12. Move the small circle to the bottom of the jarak10cm or 15cm with the Move command
13.Buatlah straight line with a small lingkarn Line in the direction of the z-axis (up size)
14. Type UCS and select 3 then click the axis origin (lower straight line), click the end of the next circle and click the upper end of the line
15. Use Polyline to create a straight line and type in a length up to make curved lines
14.Salinlah the top side to the cover image and add the line
15. Restore UCS mode to the default mode by typing UCS and enter 2 times
Surftab1 Type 16 and type 20 and Srftab2 value with a value of 20. The value to determine the density of lines
As can be seen guide Video: Click Here
16. Type Surftab1 and type in the value 20 and Surftab2 with a value of 20. The value to determine the density of lines
17. Select the Draw menu and then select Modeling and select Mesh and select Edge Mesh click on any line that is connected edges (maximum of 4 lines connected), after you click it will form a mesh or surface. do repeatedly
18.Kembalikan move the left side image (cover image) to the right with the Move command
20 From the Modify menu select 3D Mirror command and specify the mode YZ
If there are not clear dipanduan try to see the video: Click Here
Good luck good luck, can provide benefits to you all.
