I have a problem with a leader in Autocad 2007.
I have a special defined layer I use for ledears, dimension lines and texts.
Every time I copy a leader with text, the text becomes bold (only in model and in plot).
I tried matching properties, changing the layer, checking to see if the text is bold but it's not.
In properties and edit everything seems to be the same as the original leader and text but in the model and when I plot there is a difference (the text appears bold)
Any idea why this happens? And most important how do I make it stop?
Hello
Welcome to the Autodesk/AutoCAD Forums !
Maybe you could check that your objects are at ZERO level before copy/paste ...
On all your DWGs, please ELEV <Enter> and check that both values are ZERO, so you are "almost" sure that next drawn 2D objects will be at Z = 0 ...
FLATTEN is a command coming from Express/Bonus routines, so maybe they are not installed on your ACAD !?
Patrice BRAUD
