AutoCAD 2007/2008/2009
Active Member
chingola
Message 1 of 14 (26,896 Views)
How to convert dgn to dwg
26896 Views, 13 Replies
08-12-2009 02:13 AM
Hello mates,
Is there any simpler way of converting drawings from bently' microstation format (dgn - v7 or v8) to AutoCAD's format (dwg or dxf) without installing microstation.
*Dean Saadallah
Message 2 of 14 (26,895 Views)
Re: How to convert dgn to dwg
08-12-2009 05:02 AM in reply to: chingola
So you never were curious enough to look it up in AutoCAD's Help?
Dean Saadallah
http://LTisACAD.blogspot.com
Active Member
chingola
Message 3 of 14 (26,895 Views)
08-12-2009 08:50 AM in reply to: chingola
Every command and every procedure that one needs to use AutoCAD is included in AutoCAD's help but it becomes more clearer when someone paraphrases in more simpler terms to a beginner like me.
*Dave Drahn
Message 4 of 14 (26,895 Views)
08-12-2009 09:09 AM in reply to: chingola
Sorry I don't know the easy answer either, but do a search on these news
groups. It's been discussed many times, even fairly recently.
wrote in message news:6235569@discussion.autodesk.com...
Hello mates,
microstation.
*Dean Saadallah
Message 5 of 14 (26,896 Views)
08-12-2009 09:11 AM in reply to: chingola
HELP has three tabs, Contents, Index, and Search.
The last two are there to help quickly search through the first tab.
HELP>Index Tab>type DGN and explore.
Knowing where to go first is not an AutoCAD ability, just a reasonable
approach for anyone using something unfamiliar to look up the "Help" files.
Consider applying this to all things you are not familiar with that come
with user documentation, software/hardware/appliances and more.
Happy Cadding.
Dean Saadallah
Active Member
chingola
Message 6 of 14 (26,896 Views)
08-12-2009 10:07 AM in reply to: chingola
Ok thanks Dean. I have managed to find my way through. In case anybody else might be wondering, just type in the command "dgnimport".
Member
Andrew_Lin
Message 7 of 14 (26,897 Views)
08-25-2009 07:16 PM in reply to: chingola
Hi is there any way to get my AutoCAD 2004 to import DGN into DWG?
*None
Message 8 of 14 (26,898 Views)
08-25-2009 07:39 PM in reply to: chingola
Will the post by Pabber in the 2010 discussion help?
Member
JudyFennelly
Message 9 of 14 (26,897 Views)
08-25-2009 08:09 PM in reply to: chingola
Nope. There is not a way for AutoCAD 2004 to import DGN to DWG. You need to upgrade your AutoCAD to at least 2006.
Or search on Google/yahoo for dgn to dwg. There is an AutoDWG batch converter that I'm using now.
New Member
sanyuan
Message 10 of 14 (25,331 Views)
04-10-2012 07:37 PM in reply to: chingola
How to Convert DGN to DWG DXF
Edited by
Discussion_Admin
Post to the Community
New Post
Need installation help?
