AutoCAD 2007/2008/2009
Member
2012jim2012
Message 1 of 6 (278 Views)
Accepted Solution
How do I enable the Raster in AutoCad 2009?
278 Views, 5 Replies
08-13-2012 12:41 AM
Hello everyone,
I have just installed AutoCad 2009 on a Windows 7 PC. When I asked the end-user to come and test it to make sure she was happy with it, she asked where the Raster was?
I have looked through the software and searched google on how to open/enable the Raster but I canont see it anywhere.
Please can someone advise me on how I enable this function in AutoCad 2009?
James.
It should still be there on the drawing, unless the image got moved to another location.
Type in CLASSICIMAGE, it should tell you more about where it was.
*Expert Elite*
Patchy
Message 2 of 6 (267 Views)
Re: How do I enable the Raster in AutoCad 2009?
08-13-2012 06:00 AM in reply to: 2012jim2012
Raster doesn't come with plain Autocad, you have to buy it.
Member
2012jim2012
Message 3 of 6 (262 Views)
08-13-2012 06:40 AM in reply to: 2012jim2012
Thanks. I think I have the Raster capability installed as today I have worked out that I can go to File > Insert > Raster Image Reference.
I can select a file and see a preview but when I click OK and then OK again to open, nothing opens...
Member
2012jim2012
Message 4 of 6 (259 Views)
08-13-2012 06:48 AM in reply to: Patchy
OK.
I have found that after doing the above I had to 'specify on screen' where I would like the raster to be - as it asked when going through the opening process.
So that is that answered.
My next question is, How do I have the raster open when I load a drawing - I assume there is a setting for this somewhere?
*Expert Elite*
Patchy
Message 5 of 6 (257 Views)
08-13-2012 06:52 AM in reply to: 2012jim2012
Member
2012jim2012
Message 6 of 6 (249 Views)
08-13-2012 07:09 AM in reply to: Patchy
Brilliant.
I was saving to another location away from the raster's original location.
Once I saved back to the same location after adding in the raster it was there
Thanks everyone.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
