AutoCAD Forum
¿How can I add back this tab?
3 REPLIES 3
artista
381 Views, 3 Replies
(the top left bar with arrows: undo, redo....) (This is in the autocad 2009 version, I suposse that will be equal in later versions.
3 REPLIES 3
Alfred.NESWADBA
in reply to: artista
first I would try to reload the workspace.
If that does not work you have to start command _CUI, go to group "Quick Access Toolbars" and reconfigure it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
nestly2
Demo using 2011, so your results may be slightly different
artista
in reply to: nestly2
Indeed, thank you very much.
Simply changing the workspace to 3d modeling (with Turkish icon below) and then back to 2d workspace and already appears.
Can you believe that I was more than half an hour, looking at the options with the right mouse on the bars.
I was crazy looking for it and I had no way.
Very grateful.
”Boost
