I have a drawing with multiple blocks which has the same name ( thats why I cannot use Qselect option)
I tried using FIND and it does find the block I need by its TEXT name(1) , however I cannot find it in the drawing - once I double click it on the search results its like zooming in to the text I searched but I cannot click on it (2) and if I close the search it goes back to latest position I was and then I cannot see this block .
MosheLellouche hi,
who saids you can not QSelect a multiple block references? ofcourse you can!
without seeing your file it's hard to say what is the problem but check this:
Maybe that specific attribute is on off/freeze layer?
the block is selected because it is seen by the FIND command but the attribute is not seen and that's why you can not have the zoom
am i right?
Moshe
