AutoCAD 2007/2008/2009
Active Contributor
0 Kudos
Post 1 of 15
Fatal Error: 0x0000 exception at 4048b9h
1428 Views, 14 Replies
03-29-2006 11:09 PM
I have just installed a subscription from 2006 to 2007 Full. When I try to run AutoCAD 2007, I get this error:
"FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h". I can only click "OK" and that's it. Can anyone help me with this problem?
New Member
0 Kudos
Post 2 of 15
Re: Fatal Error: 0x0000 exception at 4048b9h
04-01-2006 07:40 PM in reply to: LucWelec
i got same problem. but dont know how to handle it.
i tried re-install, but seems useless.
*R. Robert Bell
Post 3 of 15
04-02-2006 08:16 AM in reply to: LucWelec
You *aren't* running the .NET 2 beta, are you? The release version should be
the one installed.
R. Robert Bell
wrote in message news:5129483@discussion.autodesk.com...
*Tony Tanzillo
Post 4 of 15
04-02-2006 01:08 PM in reply to: LucWelec
Did you happen to have the beta version of the
.NET Framework 2.0 installed on your machine now,
or in the past?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
New Member
0 Kudos
Post 5 of 15
04-02-2006 10:44 PM in reply to: LucWelec
oh yes i had installed Framework.
My notebook is IBM T43 with Win Xp.
.NET Framework version: v2.0.50727
Directx: 9.0C
Active Contributor
0 Kudos
Post 6 of 15
04-03-2006 02:17 AM in reply to: LucWelec
I got even worse. Now AutoCAD 2006 won't work anymore. The same problem. I have to uninstall 2006 and 2007. I installed the framework 2.0 from The website from Microsoft and then reinstall AutoCAD 2006. No results. AutoCAD 2006 don't work. The same fatal error. I had to reinstall my complete computer. Thank you Autodesk ... After a new installation I tried again AutoCAD 2006 and AutoCAD 2007. Now it the both versions work. I lost one day with this. ...
New Member
0 Kudos
Post 7 of 15
05-16-2006 07:52 AM in reply to: LucWelec
I'm getting the same error:
This occurs when I try to fire up ACAD07. 05 still functions. The only Framework 2.0 installed was straight from the acad CDs.
Distinguished Contributor
0 Kudos
Post 8 of 15
05-16-2006 09:00 AM in reply to: LucWelec
why dont you look up the fatal error and how to fix it at
http://usa.autodesk.com/adsk/servlet/ps/search?la=en&siteID=123112&catID=2334116&st=11&qt=fatal+error+&linkID=2475323
0 Kudos
Post 9 of 15
10-30-2006 01:10 PM in reply to: LucWelec
help - i just got 2007 software, i installed and ran, and on load up i got a fatal error
is this what 600.00 software upgrade is susposed to do????? help
0 Kudos
Post 10 of 15
05-11-2007 04:35 AM in reply to: LucWelec
what's the solution here, i see you posted a link, but the link has been removed. come on autodesk help us guys out here!
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
