AutoCAD 2007/2008/2009
Valued Mentor
mrkaplan
Message 1 of 8 (454 Views)
Accepted Solution
express tools wont load
454 Views, 7 Replies
01-10-2013 02:28 AM
today for no apparent reason express tools will not load  . autocad behaves as if they are not installed .
they has always worked ok before that
does anyone have an idea why this happened
and is there a fix without  reinstall from cd ?   thank you
thanks to you both . i haven tried DEMANDLOAD as i read the message too late . I might try next week .
i dont believe the  issue is related to content of support folder . (besides, it is normal) .  to my knowledge acetmain.cui has graphic interface , not core commands.
what i did finally was switch to another session  : then  expresstools loaded .
but some of acad behaviour was strange .  Adcenter and toolpalettes windows were sort of difficult to move even though LOCKUI is set to 0 .
I am starting to think this is an issue with this pc.  on any session system gives error messages,  and i am unable to load profiles because of registry error .
*Expert Elite*
Alfred.NESWADBA
Message 2 of 8 (451 Views)
Re: express tools wont load
01-10-2013 03:33 AM in reply to: mrkaplan
verify the supportpaths (that one of the paths points to the ExpressTools folder) and verify if the menu ACETMAIN is loaded.
BTW:
what info do you see (that we don't see) that makes you thinking that?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Mentor
mrkaplan
Message 3 of 8 (449 Views)
01-10-2013 04:26 AM in reply to: Alfred.NESWADBA
any express command says " no function definition"
support path are ok
*Expert Elite*
Patchy
Message 4 of 8 (443 Views)
01-10-2013 04:37 AM in reply to: mrkaplan
Check the DEMANDLOAD variable (Set it to 3)
*Expert Elite*
Alfred.NESWADBA
Message 5 of 8 (442 Views)
>> support path are ok
And looking with the Windows-explorer into the folder to which the support-path points ==> does this folder exist and are there file in it?
- alfred -
Alfred NESWADBA
Valued Mentor
mrkaplan
Message 6 of 8 (427 Views)
01-12-2013 02:40 AM in reply to: Alfred.NESWADBA
*Expert Elite*
Alfred.NESWADBA
Message 7 of 8 (419 Views)
01-12-2013 03:20 AM in reply to: mrkaplan
In that case try to repair (or if needed uninstall and reinstall) AutoCAD.
- alfred -
Alfred NESWADBA
Valued Mentor
mrkaplan
Message 8 of 8 (402 Views)
01-13-2013 10:47 PM in reply to: Patchy
DEMANDLOAD was set to 3 .
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
