AutoCAD 2007/2008/2009
Distinguished Contributor
6 Kudos
Post 1 of 13
Exporting to PDF
527 Views, 12 Replies
04-11-2011 07:37 AM
It appears that everytime I export to PDF, and then I open the PDF, it tells me that an ARIALMT font is missing? Anyway to fix this so the error goes away?
Thx
Kev
1 Kudo
Post 2 of 13
Re: Exporting to PDF
04-12-2011 12:19 PM in reply to: KevinPinks7697
with which version pf autocad are you working with
can you just do print to pdf with autocad
0 Kudos
Post 3 of 13
04-13-2011 03:08 AM in reply to: KevinPinks7697
Try getting a PDF using the Print Menu.
When selecting a printer u have the option to select 'DWG To PDF' or any other PDF Related printer name.
Then just press 'OK' and it'll ask u where to save the PDF-File.
Hope that helps,
Veggetossj
6 Kudos
Post 4 of 13
04-13-2011 05:56 AM in reply to: KevinPinks7697
This is weird, it only happens when I try to create a PDF using the "DWG to PDF" option in the print dialogue box or use the "exportpdf" command. If I create the PDF using CutePDF it is fine?
Thx
1 Kudo
Post 5 of 13
04-13-2011 06:27 PM in reply to: KevinPinks7697
u still didnt tell me which autocad version ur using
if it is 2010 or hiegher or before that
0 Kudos
Post 6 of 13
04-14-2011 12:56 AM in reply to: KevinPinks7697
@Kevin
Yeah we @ work also use CutePDF Writer as our default DWG to PDF Creator, it works fine.
@syria
Isnt it obvious he has version 2008? why else would he have posted it on a 2008 related forum?
6 Kudos
Post 7 of 13
04-14-2011 05:23 AM in reply to: KevinPinks7697
I am using AutoCAD 2010
Thx
6 Kudos
Post 8 of 13
04-14-2011 05:27 AM in reply to: KevinPinks7697
Speaking of CutePDF, the only thing I don't like about CutePDF is that wen I create a PDF it is always rotated 90 degrees, so then I have to save it to te desktop, then use another software to rotate the PDF the correct way? Do you have the same issue? How can I prevent this from happening?
Thx
Kev
*Expert Elite*
1,599 Kudos
Post 9 of 13
04-14-2011 10:42 AM in reply to: KevinPinks7697
Using R2010 and posting in R2008 forum?
Change the way DWG to PDF.PC3 handles fonts, set it to CAPTURE ALL (R2010 ability, not R2008).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
1 Kudo
Post 10 of 13
04-14-2011 11:10 AM in reply to: KevinPinks7697
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
