Hi.
I have more then 100 DWG file which contain blocks with attributes ( all at the same layer) - can I export to EXCEL the blocks attribute at one time?
Solved by Alfred.NESWADBA. Go to Solution.
starting with AutoCAD 2008 there is the command _DATAEXTRACTION available, and this command can export attribute informations from multiple block-references in multiple files. But if you can run that with 100 DWG's, I don't know, That depends on size of drawings and your hardware/operating system specifications.
- alfred -
