AutoCAD 2007/2008/2009
New Member
alexnp
Message 1 of 5 (1,140 Views)
exploded block disappears
1140 Views, 4 Replies
06-19-2008 06:33 AM
When I explode a block it disappears but will reappear if I reopen dwg. regen doesnt work. This only happens on dwgs that were created in 2007 Mech and have 2009 mech. new dwgs are fine. What can I do as I have hundreds of 2007 dwgs?\
Valued Contributor
j05h
Message 2 of 5 (1,139 Views)
Re: exploded block disappears
09-16-2008 07:00 PM in reply to: alexnp
i have the same problem although it happens to 09 blocks aswell and it sucks big time.
Distinguished Contributor
simon.black
Message 3 of 5 (1,139 Views)
09-16-2008 08:57 PM in reply to: alexnp
Have you both applied the Solid Fill Hotfix?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11316517&linkID=9240618
New Member
Blancyago
Message 4 of 5 (420 Views)
01-14-2013 09:00 AM in reply to: alexnp
Whenever you explode a block, the lines that compose the figure will go to layer 0, if the layer 0 is frozen, they will disappear. Does it solved the problem?
Alfred.NESWADBA
Message 5 of 5 (414 Views)
01-14-2013 09:51 AM in reply to: Blancyago
Sorry, that is only valid for lines that were drawn on layer 0 within the blockdefinition. And sometimes it makes sense to create blockdetails on other layers than 0.
As the thread is 5 years old I guess that I don't have to give any suggestions to go on now :smileywink:
- alfred -
Alfred NESWADBA
