AutoCAD 2007/2008/2009
Member
GregD07
Message 1 of 6 (610 Views)
Excluding Autocad.exe from DEP with 64bit PC
610 Views, 5 Replies
01-28-2013 08:51 AM
Hi.
I have been having some Fatal Error issues causing my CAD to crash when either opening files, inserting X-refs, or trying to open 'Layer Properties'
Following the forum guidance I have cleared out the REGEDIT files, and set the 'Tools' -  'options' - 'open and save' value to '0' but the problem persists.
Further research suggests I should exclude Autocad.exe from DEP (Data Execution Prevention) in the advanced tab of System Properties, however when I try to do this the system says it is not allowed on my 64bit PC.
How do I exclude the exe file on my PC, and will this solve my problems.
Greg
*Expert Elite*
dgorsman
Message 2 of 6 (594 Views)
Re: Excluding Autocad.exe from DEP with 64bit PC
01-30-2013 08:22 AM in reply to: GregD07
Sounds like UAC is set at a level that prevents such changes.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
*Expert Elite*
braudpat
Message 3 of 6 (588 Views)
01-31-2013 06:41 AM in reply to: dgorsman
Hello
I think that you have to be a Local Admin to set this ...
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
Member
GregD07
Message 4 of 6 (569 Views)
02-06-2013 02:20 AM in reply to: GregD07
Hi.
Thanks for your input.
With Windows 7 I can only control 'notifications' on the DEP. I can't actually exclude the autocad.exe from it.
Even our 'administrator' is unable to.
Any other ideas?
Greg
*Expert Elite*
Patchy
Message 5 of 6 (561 Views)
02-06-2013 06:24 AM in reply to: GregD07
It may help if you get the correct .NET FRAMEWORK for 2009
Wrong one will crash all day when it try to pop up the dialog box with those type of commands.
Member
GregD07
Message 6 of 6 (535 Views)
02-13-2013 05:35 AM in reply to: Patchy
Hi all.
I have managed to get things working by running in compatibility mode, since Windows7 has problems with Autocad 2009.
The way I did this was to right click on the Autocad icon, then on 'trouble shoot compatibility' and follow the steps.
It all works now, just a little slow to open and save files, and I've probably lost some of the extra functionality. I'm sure this is not the 'correct' thing to do, but I'd rather have it not crashing every five minutes!
Greg
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
