When trying to use the command presspull, and selecting the inside bounded areas a message "Error" analyzing internal islans" shows. I have looked this up and very little information. Any ideas?
Running AutoCAD 2007
Solved by Alfred.NESWADBA. Go to Solution.
use command _EXTRUDE instead 😉
Another method would be to start command _BPOLY, let this command create a new polyline based on your current one. This can now be used with _PRESSPULL.
- alfred -
if you check nothing wrong and Boundary command and hatch work just fine.
could be the mouse problem (or any else) if you use wireless mouse,
so i got a new wireless mouse last week and experiencing several problem as it has bug
so it can make a click by itself sometimes , very annoying
emergency solution is zoom in until it just cover the surface area you want to presspull,
hindering moving your cursor as the presspull progressing.
tho if you suspicious of the mouse just change it for better solution.
when i offset a polyiline it shows "error analysing internal islands" why is that, i cannot offset
If you would show a dwg-file with the polyline that can't be used for _OFFSET and let us know the distance you tried we would be able to tell you what's the reason. Without having the data you might get a lot of guesses, but maybe no valid suggestion for this special polyline/offset distance.
- alfred -
Use FLATTEN command on your entire or that part of the drawing which you want to hatch.
Then use BPOLY and zoom in that area which you want to hatch.
Hope this help.
