AutoCAD Forum
empty dwg upon reopening
2 REPLIES 2
auggiedog
270 Views, 2 Replies
Reopened an arlier drawing to find nothing showing. Started dwg with xrefs and began to draw directly in dwg. Now exrefs and the drafting ds not show. When i scroll over the xrefs in the xrefs window they show the preview and the base dwg shows my work. Tried reoloading, visretain... no luck. Any ideas. Thanks!!
2 REPLIES 2
pendean
in reply to: auggiedog
What size is this file?
Are you sure you opened the correct one?
Are you sure the last save was error free?
Sadly empty is empty, not much you can do about it after the fact.
auggiedog
in reply to: pendean
Was able to insert as block into another dwg. Not the best but worked. Thanks for the response.
Sent from my iPhone
”Boost
