AutoCAD 2007/2008/2009
dpropson
Message 1 of 10 (133 Views)
DWG to PDF
133 Views, 9 Replies
08-15-2007 04:41 AM
I'm looking for the best software available to convert dwg files to pdf. Thanks.
*Dean Saadallah
Message 2 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 04:51 AM in reply to: dpropson
Do you want to spend money? Look up ACROPLOT.
You do know 2007 comes with a PDF plotter already set up, under PLOT
command.
Other freebies can be had through an internet search, "free PDF driver" for
a search term.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Trim
Message 3 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 05:34 AM in reply to: dpropson
Also Illustrator works fine. Open Illu, open drawing in original size and save as PDF. Note that Illu opens everything in the drawing...
Distinguished Contributor
steve216586
Message 4 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 06:45 AM in reply to: dpropson
You asked for the "BEST". ADOBE ACROBAT DISTILLER IMO.
dpropson
Message 5 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 07:50 AM in reply to: dpropson
Thanks for all the insight. "BEST" for the cost... Also, easy to use.
We have about 100 architects. We are not on 2007 exclusively yet.
Dennis
dpropson
Message 6 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 08:02 AM in reply to: dpropson
Our experience with ACROPLOT is that it did not handle DWGs with several XREFs involved. That is what my people found before I arrived here. I can't confirm this.
*ddpcad
Message 7 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 08:08 AM in reply to: dpropson
I've been using AcroPlot for about 5 years and use a lot of XRefs. Never
had a problem with it here ??
Dave
DDP
Active Contributor
ganeagla
Message 8 of 10 (133 Views)
Re: DWG to PDF
08-15-2007 04:07 PM in reply to: dpropson
i've only ever used the free version of PDF factory, but I always find it the best pdf software that I have used.
*R.K. McSwain
Message 9 of 10 (133 Views)
Re: DWG to PDF
08-22-2007 03:56 PM in reply to: dpropson
ddpcad said the following on 8/15/2007 10:08 AM:
Never had a problem with Acroplot and XREFS here either.
R.K. McSwain
http://rkmcswain.blogspot.com
Valued Contributor
DaOtter
Message 10 of 10 (133 Views)
Re: DWG to PDF
08-23-2007 01:41 PM in reply to: dpropson
If you're just looking to create the odd PDF file, check out www.pdf995.com It will work with anything that shows up on plotted paper because it adds a print driver, not just a converter.
There's an annoying sponsor message, but you can get rid of that for the $10 purchase fee. pdf995.com also has programs for editing, and security of PDF files. Message was edited by: DaOtter
