AutoCAD Forum
DWG to PDF searchable
7 REPLIES 7
Message 1 of 8
4306 Views, 7 Replies
I use Autocad 2009 and want to convert DWG to searchable pdf. I already converted successfully one collection of DWGs, but another collection converting result is nonsearchable pdfs. What I did? I changed shk font to ttf font, set "Font as text" feature and check width of font is equal 1. I did experiment additionally: inserted my own text in existing DWG and tried convert it to searchable PDF. Result is nonsearchable pdf. I attached my DWG. And I ask experts: please, what is wrong with this DWG?
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
I'm not sure what happend with your drawing, but there seem to be a lot of problems in it's database, e.g. I run _AUDIT with AutoCAD 2014 and it found 812 errors!
The only thing I found to get it working was to use _COPYBASE and _PASTECLIP to copy the whole geometry into a new drawing, then the PDF created from that new drawing was searchable.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
pendean
Also ensure that you are using TTF fonts, not AutoCAD SHX stick fonts, and you have not STYLE assigned widths.
Message 4 of 8
in reply to: Alfred.NESWADBA
Thanks everybody who answered!
Dear Alfred, your advice to do copy - paste works wonderful! But sometimes copy - paste doesn't work. It copies, but pastes nothing. I have not idea, why it happens.
Message 5 of 8
Alfred.NESWADBA
Well, there might be several reasons like
  • blocks with the same names exist already in the destination drawing, but are different
  • frozen layers in the destination drawing
  • usage of a vertical application (like Civil3D, Architecture, Mechanical, ... or application that created proxies)
  • missing ZOOM EXTENTS after paste
  • ....and a lot more, if you search through this forum here you'll find a lot threads about such issue (and solutions in some cases too).
    - alfred -
    Alfred NESWADBA
    Message 6 of 8
    Dear experts!
    Adventures with searchable PDFs are still goes on. Now I trying to plot dwg to searchable pdf for another type of equipment. But not successfully. I changed text styles from shx to ttf, did copy-paste to new blank drawing. But not searcheable pdf is result. I have no idea what can I do with my file else. File is attached here.
    Message 7 of 8
    Alfred.NESWADBA
    in the uploaded drawing your styles are set to SHX, not TTF (DIN8.SHX and TXT.SHX)
    And Width-Factor (which has to be 1.0) is set to 1.09.
    After correcting that 2 settings the PDF is searchable.
    - alfred -
    Alfred NESWADBA
    Message 8 of 8
    Thank you, Alfred!
    I saw witdh factor in "Text style" window, where it is equal 1.000. But width factor is in text properties also, where it is equal 1,09.
    Beloborod
    ”Boost
