AutoCAD 2007/2008/2009
Active Member
PAULMAYCO
Message 1 of 2 (664 Views)
Draw order and xrefs
664 Views, 1 Replies
01-28-2013 08:34 AM
Hi all,
I'm currently trying to make a new template by xrefing items in.
I need to make part of the template xref have an "always sit on top" option, so that any viewport drawn by other people will appear behind the xref.
Is there a simple way of doing this or do I just have to inform people to use the bring to front option on the xref before they issue or print the drawing?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 2 (653 Views)
Re: Draw order and xrefs
01-28-2013 09:53 AM in reply to: PAULMAYCO
"part of the XRef" is not an option as a XRef is one object, so in the order of how objects are regenerated/displayed it can only have one position in it. You can't do some XRef-objects behind and others on top of your current drawing-geometry.
So that sounds you don't mean "parts of a XRef"?
Anyway, if you want to plot everything on paperspace later then geometry object in viewports you can check the option "Plot paperspace last" in the plot-dialog (if you prepare page-setups you can also do that there).
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Post to the Community
New Post
Need installation help?
