AutoCAD Forum
Do not save in AutoCAD and delete all data
7 REPLIES 7
Message 1 of 8
ahmedrefaey
589 Views, 7 Replies
When working on AutoCAD 2009 after five minutes deletes planned nor fully appreciate the work Save the file, which it
What is the solution to work with the same problem when using Autocad 2013
7 REPLIES 7
Message 2 of 8
pendean
in reply to: ahmedrefaey
Can you explain in more detail please?
Message 3 of 8
ahmedrefaey
in reply to: pendean
يعني اما اجى احفظ المخطط وانا شغال  بعد خمس دقائق  يتحذف المخطط كلة ويجيب  شاشة سوداء  واما  اجى  اطلع من الاوتوكاد  وادخل على المخطط عادى  مش بلاقى عليه اى حاجة
Message 4 of 8
pendean
Are you using 2013 or 2009?
Is this a new problem? AutoCAD 2009 is not new, neither is 2013? Do you have a new PC or a recent change to your system?
AutoCAD crashing or going blank after 5-minutes from starting is unusual.
Message 5 of 8
ahmedrefaey
انا بستخدم حاليا 2009
وبيظهر فيه المشلكة دي ومش عارف حلها  فايرس هو او من البرنامج ولا من اية لانه بيحذف جيمع العمل على المخطط يعنى  اكون بشتغل  وخمس دقائق  يشيل كل شئ
 وفى نفس الاصدار 2013  بيحصل  نفس  الكلام
 شكار ليك على الردرد
Message 6 of 8
Bob_Zurunkle
I'd wonder if the program is fully patched...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 7 of 8
pendean
Which Windows version are you using? Did you use the 'migrate' option between 2009 and 2013?
Do you have AUTOSAVE set to 5-minutes by chance? What happens if you set it to 10 minutes? Does AutoCAD crash at the 10-minute mark?
Are your files on a server, or on your PC?
Message 8 of 8
ahmedrefaey
I use Microsoft Windows 7 32-bit
Use Autocad 2009, and sometimes 2013
I'm not nearly isogenic these options
Planned on the computer device.
”Boost
