AutoCAD 2007/2008/2009
Valued Contributor
jgodown
Message 1 of 6 (508 Views)
Distance command
508 Views, 5 Replies
11-11-2009 12:54 PM
When I type the distance command and hit enter it gives me "DISTANCE = 0 (read only)" it does not allow me to pick any points, anyone know how to fix this
*Expert Elite*
Message 2 of 6 (508 Views)
Re: Distance command
11-11-2009 12:57 PM in reply to: jgodown
command is DIST
Valued Contributor
jgodown
Message 3 of 6 (508 Views)
11-11-2009 01:11 PM in reply to: jgodown
That did it, thank you
*Pro
Modman_4
Message 4 of 6 (508 Views)
11-12-2009 06:28 AM in reply to: jgodown
DI for short...
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Distinguished Contributor
calfcreek
Message 5 of 6 (226 Views)
08-22-2012 08:51 AM in reply to: ToanDN
This just happened to me and I had to change my .pgp file to "DIST"
That is insane! What on earth is the purpose of a 'read only' command?
These are the times that try Men's souls.....:smileysad:
*Expert Elite*
dgorsman
Message 6 of 6 (221 Views)
08-22-2012 09:05 AM in reply to: calfcreek
DIST is a command
DISTANCE is a system variable
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
