AutoCAD 2007/2008/2009
Appleroofing
Message 1 of 8 (1,713 Views)
Distance command (DI) not showing correct measurement
1713 Views, 7 Replies
01-02-2013 06:01 AM
Distance command (DI) not showing correct measurement in the bottom left hand corner in autocad 2009. Does anyone know how to get that to show the correct dimension when I DI a line.
Sean
Alfred.NESWADBA
Message 2 of 8 (1,706 Views)
Re: Distance command (DI) not showing correct measurement
01-02-2013 06:22 AM in reply to: Appleroofing
Can you show us an example? Upload a drawing and tell us what you did and what AutoCAD reported. We haven't seen what your drawing contains (especially 2D or 3D), what objectsnaps you had active, what AutoCAD told you how long the line is and what the property-window tells you about the line-length, if you were in modelspace or layout/paperspace ....
At least we don't have enough info's to answer your question.
- alfred -
Alfred NESWADBA
Appleroofing
Message 3 of 8 (1,698 Views)
01-02-2013 06:27 AM in reply to: Alfred.NESWADBA
It is the measurements below the command prompt in the left hand bottom corner. In paper space it works fine, but in model space the measurements are all over the place. It worked fine before.
Valued Contributor
Patchy
Message 4 of 8 (1,690 Views)
01-02-2013 06:39 AM in reply to: Appleroofing
Take a snapshot of the screen and attach it here, let's see all over the place looks like.
Alfred.NESWADBA
Message 5 of 8 (1,689 Views)
01-02-2013 06:41 AM in reply to: Appleroofing
In the lower left corner of the status-line there is shown a coordinate of where your are, that has nothing to do with the length of the line or the result of a distance-command.
Maybe it's a help if you look to the WCS/UCS: have you created a user-defined coordinate system (UCS)? If so, the coords shown in this lower-left corner area show you the UCS-coords, not the ones from the world coordinate system. What happens if you switch to WCS using command _UCS ==> option _WORLD?
Again: we don't see your AutoCAD/your drawing, so we don't know what coords AutoCAD shows you and where your cursor is.
- alfred -
Alfred NESWADBA
Appleroofing
Message 6 of 8 (1,688 Views)
01-02-2013 06:44 AM in reply to: Appleroofing
I just clicked on the drawing coordinates and clicked it back on and know it seems to be working fine.
Thanks everyone
New Member
marlo5
Message 7 of 8 (862 Views)
02-19-2014 04:27 PM in reply to: Appleroofing
I`m having the exact same problem.
As you can see in the 2 example jpg`s when i simply use the AutoCAD command distance for 2 lines offset 1200 apart, it displays 1200. GREAT.
BUT when i offest a line on a 45 degree angle at say 1500 the distance command displays 1060.7.
BUT when you use Angular Dimension it dimension correctly showing 1500.
Any advice please.
cheers
kel
New Member
marlo5
Message 8 of 8 (847 Views)
02-19-2014 07:14 PM in reply to: marlo5
Sorry, false alarm.
Silly me simply had 2 lines of the command line showing.
I`ve since stratched it make 3 lines.
Now i see the Distance, Angle, etc..
It was always there!!!:smileysurprised:
thanks in advance.
marlo:smileysurprised:
