AutoCAD 2007/2008/2009
Active Contributor
Aphyosemion
Message 1 of 15 (625 Views)
Disappearing paper/model space button
625 Views, 14 Replies
09-24-2008 12:15 PM
A coworker and I have been having issues with the paper/model space button on the taskbar periodically disapperaring for no apparent reason. You can then go into the taskbar settings and turn it back on, but eventually it disappears again. My coworker mentioned that his has disappeared 3 times today and he hasn't changed profiles or workspaces or anything that might affect it.
Has anyone else had this problem and do you know what might cause it to randomly turn off? We are wondering if there is some sort of button combination that turns it off that we are accidently hitting or something along those lines.
-Aphyosemion Edited by: Aphyosemion on Sep 24, 2008 2:16 PM
Distinguished Contributor
neeboy74
Message 2 of 15 (625 Views)
Re: Disappearing paper/model space button
09-24-2008 12:55 PM in reply to: Aphyosemion
Search the forums here; it's been brought up before and it appears to be a known "bug" in at least 2008. I have not used 2009 on my secondary computer long enough to determine if it'll pop up there too.
*Expert Elite*
M_Hensley
Message 3 of 15 (625 Views)
09-25-2008 03:29 AM in reply to: Aphyosemion
This is a known bug. It is caused by the block editor. There is no fix available, you just have to keep turning it back on (or learn to get by without it)
ChrisCAD27
Message 4 of 15 (625 Views)
09-25-2008 11:49 AM in reply to: Aphyosemion
AutoCAD has so many little bugs like this that never get fixed. Its like they had one prodigal programmer who designed all this stuff then quit and no one has any idea how to fix anything, so they just keep adding new stuff on top of the broken stuff.
*fieldguy
Message 5 of 15 (625 Views)
09-25-2008 12:01 PM in reply to: Aphyosemion
That was the same person who could spell and had
reasonable grammer skills.  But, that was also back when it used to
matter.
was_saxman
Message 6 of 15 (625 Views)
11-12-2008 07:49 AM in reply to: Aphyosemion
ahem........it is "grammar"
*fieldguy
Message 7 of 15 (625 Views)
11-13-2008 07:41 AM in reply to: Aphyosemion
darn! good catch
RStillwell
Message 8 of 15 (625 Views)
11-13-2008 09:59 AM in reply to: Aphyosemion
I've added the following to my S::smileyfrustrated:TARTUP and it keeps the button on.
(setq regProfRoot (strcat "HKEY_CURRENT_USER\\" (vlax-Product-Key) "file://profiles//" (getvar "CProfile")))
(setq RegNow (strcat regProfRoot "file://statusbar//Application"))
(vl-registry-write RegNow "Paper/ModelPane" 1);turn on the model/paper status bar
Active Member
dpettay
Message 9 of 15 (625 Views)
01-28-2009 01:49 PM in reply to: Aphyosemion
Can you explain adding this to S::smileyfrustrated:TARTUP ? Thanks so much.
Member
rjfmich1961
Message 10 of 15 (625 Views)
02-04-2009 08:53 AM in reply to: Aphyosemion
Any help? This is a continuing problem that I have as well...
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
