AutoCAD 2007/2008/2009
New Member
jedijermx
Message 1 of 4 (178 Views)
dimscale replacement
178 Views, 3 Replies
06-19-2009 07:25 AM
I have a lsp routine
that breaks a line in both directions the distance is per
the dimscale
now the dim scale is basicly off with annotative scaling on
is there another comand that can be used in its place
i tried cannoscalevalue but the #'s it gives back gets bigger the smaller the scale is
(the oposite of how dimscale worked)
lsp below
(defun C:BL (/ omode a b c pt1)
(defun *error* ()
(setvar "orthomode" omode)
(setvar "osmode" osmod)
(princ "\nError detected...aborting")
(terpri)
(setq SCL (getvar "dimscale"))
(setq omode (getvar "orthomode"))
(setq osmod (getvar "osmode"))
(setvar "orthomode" 1)
(setvar "osmode" 32)
(setq a (getpoint "\nSelect INTERSECTION :"))
(setvar "osmode" 512)
(INITGET "X")
(setq pt1 (getpoint a (strcat "\nSCL=" (RTOS SCL 2 2) "-Please pick lower line Yizil: Nea ")))
(if (= PT1 "X")
(progn
(*error*)
(exit)
(setvar "osmode" 0)
(setq b (angle a pt1))
(setq c (* SCL 0.040))
(COMMAND "BREAK" PT1 "F" (POLAR A B (- C)) (POLAR A B C))
any ideas
any help would be great
GrantsPirate
Message 2 of 4 (178 Views)
Re: dimscale replacement
06-19-2009 01:02 PM in reply to: jedijermx
Divide the cannoscalevalue into 1
1 / 0.0208333333 = 48
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
New Member
jedijermx
Message 3 of 4 (178 Views)
06-22-2009 06:49 AM in reply to: jedijermx
do you know how to write that in the above script?
GrantsPirate
Message 4 of 4 (178 Views)
06-22-2009 01:19 PM in reply to: jedijermx
(setq SCL (/ 1.0 (getvar "cannoscalevalue")))
I make no claims to being an accomplished lisp writer, but the above should work.
