AutoCAD 2007/2008/2009
pmahaffy001
Message 1 of 15 (222 Views)
Dimension text Help
222 Views, 14 Replies
06-15-2012 06:41 AM
I am developing some menus / standards for everyone who uses acad in my office, i am almost there but am having trouble getting the dimensions to do what i want.
I use standard text heights of 1.8mm, 2.5mm, 3.5mm and 5.0mm depending on what i need.
my dimensions are either 1.8mm @ 1: xx scale or 2.5 @ 1: xx scale.
the drop down i have developed allows you to chose the scale your drawing at and import whatever size dim / text you need by using macros.
when i click to import 1.8mm_1:1250 dim option it pulls in the dimension style perfectly but the text is 2.5mm not 1.8 in the viewport.
i use the following macro could someone just have a look over it to see where i am going wrong.
^C^CMenuecho;3;^PExpert;5;_-style;"arial";arial.ttf;;;;;;;DIMTXT;2250;DIMTXSTY;arial;DIMTOL;0;DIMLIM;0;DIMTIH;0;DIMTOH;0;DIMSE1;0;DIMSE2;0;DIMALT;0;DIMTOFL;0;DIMSAH;1;DIMTIX;0;DIMSOXD;0;DIMSD1;0;DIMSD2;0;DIMUPT;0;DIMTOLJ;1;DIMDSEP;.;DIMZIN;9;DIMJUST;0;DIMFIT;3;DIMTZIN;0;DIMALTTZ;0;DIMTAD;1;DIMUNIT;2;DIMAUNIT;0;DIMDEC;1;DIMTDEC;1;DIMALTTD;4;DIMADEC;1;DIMAZIN;0;DIMATFIT;3;DIMFRAC;0;DIMLUNIT;2;DIMTMOVE;0;DIMASZ;1.5;DIMEXO;2;DIMDLI;5;DIMEXE;2;DIMRND;0;DIMDLE;2;DIMTP;0;DIMTM;0;DIMCEN;3;DIMTSZ;0;DIMLFAC;1;DIMTVP;0;DIMTFAC;1;DIMGAP;1;DIMPOST;.;DIMBLK;.;DIMBLK1;ArchTick;DIMBLK2;ArchTick;DIMLDRBLK;_Dot;DIMCLRD;0;DIMCLRE;0;DIMCLRT;2;DIMLWD;-2;DIMLWE;-2;DIMSCALE;1250;-dimstyle;s;"1.8 1-1250 dims";expert;0;menuecho;0;^P^C^C
*Expert Elite*
Patchy
Message 2 of 15 (217 Views)
Re: Dimension text Help
06-15-2012 06:56 AM in reply to: pmahaffy001
How long have you used Autocad ?
Did you know you can use Annotative feature if you want all texts to look the same in paperspace?
pmahaffy001
Message 3 of 15 (215 Views)
06-15-2012 07:00 AM in reply to: Patchy
i have used it a long time, but i have never really used the annotative aspects of it.  i was trying to create something for my colleagues who are relatively new to acad as they primarily use another software.  we are still at the whats an xref and where is that layer stage.  I used this method of importing text / dim styles at my previous place of work and its relatively straight forward and everyone picked it up within a few tries!
pmahaffy001
Message 4 of 15 (203 Views)
06-15-2012 07:25 AM in reply to: pmahaffy001
I understand that, just thought there was a reason why it would not go in at that particular scale and would default to 2.5 when the macro specifically tells it otherwise!!!
*Expert Elite*
Patchy
Message 5 of 15 (195 Views)
06-15-2012 07:35 AM in reply to: pmahaffy001
Attach your drawing, it's easier to see what's wrong than running your macro.
pmahaffy001
Message 6 of 15 (192 Views)
06-15-2012 07:59 AM in reply to: Patchy
Right here is the process of getting my dimension into the drawing, which loads fine, (image file)
the typical dimension that actually imports using that macro is as the drawing attached.
*Expert Elite*
Patchy
Message 7 of 15 (187 Views)
06-15-2012 08:03 AM in reply to: pmahaffy001
Try this
pmahaffy001
Message 8 of 15 (180 Views)
06-15-2012 08:12 AM in reply to: Patchy
thank you for trying, i have tried this but still when i bring it n its got a text height of 2.5mm instead of 1.8mm as shown on attached
*Expert Elite*
Patchy
Message 9 of 15 (161 Views)
06-15-2012 08:34 AM in reply to: pmahaffy001
style;"arial";arial.ttf;;;;;;;DIMTXT  <-<-<- Should there be a DIMTXT with value here??
pmahaffy001
Message 10 of 15 (157 Views)
06-15-2012 08:46 AM in reply to: Patchy
^C^CMenuecho;3;^PExpert;5;_-style;"arial";arial.ttf;;;;;;;DIMTXT;2250;DIMTXSTY;arial;DIMTOL;0;DIMLIM;0;DIMTIH;0;DIMTOH;0;DIMSE1;0;DIMSE2;0;DIMALT;0;DIMTOFL;0;DIMSAH;1;DIMTIX;0;DIMSOXD;0;DIMSD1;0;DIMSD2;0;DIMUPT;0;DIMTOLJ;1;DIMDSEP;.;DIMZIN;9;DIMJUST;0;DIMFIT;3;DIMTZIN;0;DIMALTTZ;0;DIMTAD;1;DIMUNIT;2;DIMAUNIT;0;DIMDEC;1;DIMTDEC;1;DIMALTTD;4;DIMADEC;1;DIMAZIN;0;DIMATFIT;3;DIMFRAC;0;DIMLUNIT;2;DIMTMOVE;0;DIMASZ;1.5;DIMEXO;2;DIMDLI;5;DIMEXE;2;DIMRND;0;DIMDLE;2;DIMTP;0;DIMTM;0;DIMCEN;3;DIMTSZ;0;DIMLFAC;1;DIMTVP;0;DIMTFAC;1;DIMGAP;1;DIMPOST;.;DIMBLK;.;DIMBLK1;ArchTick;DIMBLK2;ArchTick;DIMLDRBLK;_Dot;DIMCLRD;0;DIMCLRE;0;DIMCLRT;2;DIMLWD;-2;DIMLWE;-2;DIMSCALE;1250;-dimstyle;s;"1.81-1250dims";expert;0;menuecho;0;^P^C^C
is still giving me as shown on image
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
