AutoCAD 2007/2008/2009
Valued Contributor
4 Kudos
Post 1 of 9
Dimension style - text position
913 Views, 8 Replies
07-30-2012 10:56 AM
Hello Forum,
I create a dimension style as follows:
The dimension style is architectural, above line, alligned with line.
It also has alternate units; decimal, below primary value.
Now if I place a horizontal dimension, all is fine. But as soon as I move the dimension text with its grip, the text drops down a bit, intersecting with the line. Also, after the move the property "Text Offset" is not used anymore.
How do I fix this? How can I move the dimension text without problems?
Thank you.
"It also has alternate units; decimal, below primary value."  From your original post, hmm??
After you move the text and it, " drops down a bit", select the text for editing by double clicking on it.  After the Primary unit measurement hit keyboard "enter".  This will leave a text line space between the primary and alternate units.
What you have now:
<> (Primary)
<> (Secondary
What you will have after doing the above:
<>"ENTER" (Primary)
(blank line space)
<> (Secondary)
I hope this clears things up.
24 Kudos
Post 2 of 9
Re: Dimension style - text position
08-03-2012 11:43 AM in reply to: Ertqwa
This problem happens firstly with "Bellow primary value", then plus with the dimension text has fraction in Architectural unit format. AutoCAD does not locate the text correctly with those dimension settings. When we move the text, it will drop down a bit. To fix that, right click on the dimension, choose 'Dim Text position" menu, select "Move text with leader", and then try to move the text not to intersect with the line. The final text will look shorter but at least it helps to trick this AutoCAD issue.
-Khoa
Valued Contributor
4 Kudos
Post 3 of 9
08-18-2012 11:43 PM in reply to: khoa.ho
Thank you for the reply.
Unfortunately this does not solve the issue.
67 Kudos
Post 4 of 9
08-22-2012 03:29 PM in reply to: Ertqwa
Look into DIMFRAC = 2
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
Valued Contributor
4 Kudos
Post 5 of 9
09-21-2012 11:46 AM in reply to: scot-65
Unfortunately DIMFRAC = 2 does not solve the issue.
*Pro
138 Kudos
Post 6 of 9
10-22-2012 11:35 AM in reply to: Ertqwa
This may sound a little bit cumbersome but try placing a return (keyboard - ENTER) after the first dimension.  Basically, you will be leaving a blank line of text between the primary and secondary dimensions.  Hope that helps.
Valued Contributor
4 Kudos
Post 7 of 9
10-28-2012 12:55 AM in reply to: steve216586
Hi, ty for you response.
I'm not sure what you mean. I only have one textoverride in properties and that overrides both. So <> keeps them together.
*Pro
138 Kudos
Post 8 of 9
10-31-2012 07:04 AM in reply to: Ertqwa
What you have now:
<> (Primary)
<> (Secondary
<>"ENTER" (Primary)
(blank line space)
<> (Secondary)
Valued Contributor
4 Kudos
Post 9 of 9
11-08-2012 11:29 AM in reply to: steve216586
Your suggestion didn't work at first because I typed <>\P<> but you have to type <>\P[].
Thank you.
