AutoCAD 2007/2008/2009
Spreemann
Message 1 of 2 (127 Views)
dimension across viewports of same 3D model in layout view
127 Views, 1 Replies
03-23-2009 04:58 AM
I have a 3D model
It is long & thin - too long to show clearly in layout view.
I scaled it up & have shown it as 2 viewports with break lines between them.
Looks good but can I dimension across the viewports?
I don't want to manually edit the dimensions - too much scope for error & besides I'm far too lazy to do that.
Using 2009 Mechanical..
*Phantomdrafter
Message 2 of 2 (127 Views)
Re: dimension across viewports of same 3D model in layout view
03-23-2009 09:05 AM in reply to: Spreemann
If there is I haven't found it. What I do is make a temp viewport of
the whole part, dim it, explode the dims and cut & paste the dim text
into the split viewport dims. Makes it a little more accurate than
manual edit.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
