AutoCAD 2007/2008/2009
*Paul
Message 1 of 16 (667 Views)
devide a line equally
667 Views, 15 Replies
08-07-2008 12:35 PM
I want to devide a line of unknown length in f.e. sections of equal
length. (example line is 397 mm and I need 6 equal sections of 66.16
mm)
Can someone help me?
Greetings Paul
Groeten Paul
Distinguished Contributor
nvanlaar
Message 2 of 16 (667 Views)
Re: devide a line equally
08-07-2008 12:49 PM in reply to: *Paul
Use the MEASURE command.
MEASURE > select object > put in distance
Same is true for DIVIDE except instead of the length you input the number of
pieces.
These two commands will also insert blocks instead of points at the
determined distances. Explore them in the Help File.
"Paul" wrote in message
news:6001288@discussion.autodesk.com...
mm)
Greetings Paul
Groeten Paul
*ddpcad
Message 3 of 16 (667 Views)
08-07-2008 12:50 PM in reply to: *Paul
Paul wrote:
> Hello,
> mm)
> Greetings Paul
Command: divide
Select object to divide:
Enter the number of segments or [Block]: 6
Dave
DDP
Valued Contributor
btheboz
Message 4 of 16 (667 Views)
08-07-2008 12:52 PM in reply to: *Paul
Are you really needing the answer to that question or are you just pulling everyones chain? Type divide at the command line, and input the number of segements. It will place a node at the division points, but will leave the entity intact.
*Paul
Message 5 of 16 (667 Views)
08-07-2008 01:01 PM in reply to: *Paul
Paul heeft uiteengezet op 7-8-2008 :
> Hello,
> mm)
> Greetings Paul
.....thanks everybody and excuse me for misspelling "devide"
Greetings Paul
Groeten Paul
*Tony Tanzillo
Message 6 of 16 (667 Views)
08-07-2008 02:03 PM in reply to: *Paul
You might want to consider getting some rudimentry
AutoCAD training, because your question is very basic
and only something a complete beginner would need
to ask.
It just doesn't make sense to spend $3-4K on very
complicated CADD software, while investing nothing
in learning how to use it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"Paul" wrote in message news:6001288@discussion.autodesk.com...
mm)
Greetings Paul
Groeten Paul
kingtut
Message 7 of 16 (668 Views)
08-07-2008 02:11 PM in reply to: *Paul
Give him a break, what if he tried it but with node turned off and saw nothing ?????
*Murph
Message 8 of 16 (668 Views)
08-07-2008 03:10 PM in reply to: *Paul
"kingtut" wrote in message news:6001397@discussion.autodesk.com...
< Give him a break, what if he tried it but with node turned off and saw
nothing ?????
Cause basic CAD training would of explained how to set a point style to see
the node.
But I agree to cut the OP some slack, with all the 3rd party add-ons and
verticals a lot of users don't know the simple commands from the R-9 days.
Murph
www.map3d.wordpress.com
*Tony Tanzillo
Message 9 of 16 (668 Views)
08-07-2008 07:02 PM in reply to: *Paul
Then he would have told us that.
*Dilip Damle
Message 10 of 16 (668 Views)
08-07-2008 09:26 PM in reply to: *Paul
On Fri, 08 Aug 2008 01:05:18 +0530, Paul wrote:
> Hello,
> mm)
> Greetings Paul
Print this and keep it on your table.
This list is from 2008
you may add commands from 2009 (In that process you will learn more :smileyhappy: )
List of Autocad commands
3D :: Createsthree-dimensional polygon mesh objects in common geometric shapesthat can be hidden, shaded, or rendered
3DALIGN :: Aligns objects with other objects in 2D and3D
3DARRAY :: Createsa three-dimensional array
3DCLIP :: Starts an interactive3D view and opens the Adjust Clipping Planes window
3DCONFIG :: Provides3D graphics system configuration settings
3DCORBIT :: Starts an interactive3D view and sets the objects into continuous motion
3DDISTANCE :: Startsthe interactive 3D view and makes objects appear closer or farther away
3DDWF :: Createsa 3D DWF file of your three-dimensional model and displays it inthe DWF Viewer
3DDWFPUBLISH :: Obsolete
3DFACE :: Creates a three-sided or four-sided surface anywherein 3D space
3DFLY :: Interactivelychanges your view of a 3D drawings so that you appear to be flyingthrough the model
3DFORBIT :: Controlsthe interactive viewing of objects in 3D, using an unconstrained orbit
3DMESH :: Createsa free-form polygon mesh
3DMOVE :: Displaysthe move grip tool in a 3D view and moves objects a specified distancein a specified direction
3DORBIT :: Controlsthe interactive viewing of objects in 3D
3DORBITCTR :: Setsthe center of rotation in 3D Orbit view
3DPAN :: Whena drawing is in a Perspective view, starts the interactive 3D viewand enables you to drag the view horizontally and vertically
3DPOLY :: Creates a polyline of line segments in 3Dspace
3DROTATE :: Displays the rotate grip tool in a 3D view andrevolves objects around a base point
3DSIN :: Importsa 3D Studio (3DS) file
3DSOUT :: Obsolete
3DSWIVEL :: Changesthe target of the view in the direction that you drag
3DWALK :: Interactivelychanges the view of a 3D drawing so that you appear to be walkingthrough the model
3DZOOM :: Zoomsin and out in a perspective view
ABOUT :: Displays information about AutoCAD
ACISIN :: Imports anACIS file and creates a body object, solid, or region in the drawing
ACISOUT :: Exportsa body object, solid, or region to an ACIS file
ADCCLOSE :: Closes DesignCenter
ADCENTER :: Manages and inserts content such as blocks,xrefs, and hatch patterns
ADCNAVIGATE :: Loads a specified DesignCenterdrawing file, folder, or network path
AMECONVERT :: Converts AME solid models to AutoCADsolid objects
ANIPATH :: Saves an animation along a path ina 3D model
ANNORESET :: Resets the location of all < >
ANNOUPDATE :: Updatesexisting < >
APERTURE :: Controls the sizeof the object snap target box
APPLOAD :: Loads and unloads applications and defines whichapplications to load at startup
ARC :: Creates an arc
ARCHIVE :: Packages the current sheet set files to be archived
AREA :: Calculates the area and perimeter of objectsor of defined areas
ARRAY :: Createsmultiple copies of objects in a pattern
ARX :: Loads,unloads, and provides information about ObjectARX applications
ATTACHURL :: Attaches hyperlinks to objects or areas in adrawing
ATTDEF :: Creates an attribute definition
ATTDISP :: Globallycontrols visibility of block attributes in a drawing
ATTEDIT :: Changesattribute information in a block
ATTEXT :: Extracts attribute data, informationaltext associated with a block, into a file
ATTIPEDIT :: Changes the textual content of an attributewithin a block
ATTREDEF :: Redefinesa block and updates associated attributes
ATTSYNC :: Updatesall instances of a specified block with the current attributes defined forthe block
AUDIT :: Evaluatesthe integrity of a drawing and corrects some errors
AUTOPUBLISH :: Publishesdrawings to DWF files automatically
BACKGROUND :: Obsolete. BACKGROUND functionality has beenmerged into the VIEW command.
BACTION :: Adds an action to a dynamicblock definition
BACTIONSET :: Specifies the selectionset of objects associated with an action in a dynamic block definition
BACTIONTOOL :: Adds an action to a dynamicblock definition
BASE :: Sets the insertionbase point for the current drawing
BASSOCIATE :: Associates an actionwith a parameter in a dynamic block definition
BATTMAN :: Editsattribute properties of a block definition
BATTORDER :: Specifies the order ofattributes for a block
BAUTHORPALETTE :: Opensthe Block Authoring Palettes window in the Block Editor.
BAUTHORPALETTECLOSE :: Closes the Block Authoring Palettes windowin the Block Editor
BCLOSE :: Closes the Block Editor
BCYCLEORDER :: Changes the cycling orderof grips for a dynamic block reference
BEDIT :: Opens the Edit BlockDefinition dialog box and then the Block Editor
BGRIPSET :: Creates, deletes, orresets grips associated with a parameter
BHATCH :: Fillsan enclosed area or selected objects with a hatch pattern or gradientfill
BLIPMODE :: Controlsthe display of marker blips
BLOCK :: Creates a block definition from objectsyou select
BLOCKICON :: Generatespreview images for blocks displayed in DesignCenter
BLOOKUPTABLE :: Displaysor creates a lookup table for a dynamic block definition
BMPOUT :: Saves selected objectsto a file in device-independent bitmap format
BOUNDARY :: Creates a region or a polyline from anenclosed area
BOX :: Createsa 3D solid box
BPARAMETER :: Adds a parameter withgrips to a dynamic block definition
BREAK :: Breaksthe selected object between two points
BREP :: Removes the history from 3D solid primitives and composite solids
BROWSER :: Launches the default web browserdefined in your system's registry
BSAVE :: Saves the current blockdefinition
BSAVEAS :: Saves a copy of the currentblock definition under a new name
BVHIDE :: Makes objects invisiblein the current visibility state or all visibility states in a dynamicblock definition
BVSHOW :: Makes objects visiblein the current visibility state or all visibility states in a dynamicblock definition
BVSTATE :: Creates, sets, or deletesa visibility state in a dynamic block
CAL :: Evaluates mathematical and geometric expressions
CAMERA :: Sets a camera and target location to createand save a 3D perspective view of objects
CHAMFER :: Bevels the edges of objects
CHANGE :: Changes the propertiesof existing objects
CHECKSTANDARDS :: Checksthe current drawing for standards violations
CHPROP :: Changesthe properties of an object
CHSPACE :: Movesobjects from model space to paper space, or vice versa
CIRCLE :: Createsa circle
CLEANSCREENOFF :: Restores display of toolbars and dockable windows(excluding the command line)
CLEANSCREENON :: Clears the screen of toolbars and dockable windows(excluding the command line)
CLOSE :: Closesthe current drawing
CLOSEALL :: Closes all currently open drawings
COLOR :: Sets the color for newobjects
COMMANDLINE :: Displaysthe command line
COMMANDLINEHIDE :: Hides the command line
COMPILE :: Compiles shape files and PostScript font filesinto SHX files
CONE :: Creates a 3D solid with a circular or ellipticalbase tapering symmetrically to a point or a circular or ellipticalplanar face
CONVERT :: Optimizes 2Dpolylines and associative hatches created in AutoCAD Release 13or earlier
CONVERTCTB :: Convertsa color-dependent plot style table (CTB) to a named plot style table(STB)
CONVERTOLDLIGHTS :: Convertslights created in previous releases to lights in AutoCAD 2007 format
CONVERTOLDMATERIALS :: Convertsmaterials created in previous releases to materials in AutoCAD 2007format
CONVERTPSTYLES :: Convertsthe current drawing to either named or color-dependent plot styles
CONVTOSOLID :: Converts polylines and circles with thicknessto 3D solids
CONVTOSURFACE :: Convertsobjects to surfaces
COPY :: Copiesobjects a specified distance in a specified direction
COPYBASE :: Copiesobjects with a specified base point
COPYCLIP :: Copies objectsor command prompt text to the Clipboard
COPYHIST :: Copies the text in the command prompthistory to the Clipboard
COPYLINK :: Copiesthe current view to the Clipboard for linking to other OLE applications
COPYTOLAYER :: Copies one or more objects to another layer
CUI :: Managescustomized user interface elements such as workspaces, toolbars, menus,shortcut menus and keyboard shortcuts
CUIEXPORT :: Exports customized settingsto an enterprise or partial CUI file
CUIIMPORT :: Imports customized settingsfrom an enterprise or partial CUI file to acad.cui
CUILOAD :: Loads a CUI file
CUIUNLOAD :: Unloadsa CUI file
CUSTOMIZE :: Customizestool palettes and tool palette groups
CUTCLIP :: Copiesobjects to the Clipboard and removes the objects from the drawing
CYLINDER :: Creates a three-sided 3D solid with a circularor elliptical base and top
DASHBOARD :: Opens the Dashboard window
DASHBOARDCLOSE :: Closes the Dashboard window
DATAEXTRACTION :: Exportsobject property, block attribute, and drawing information to a data extractiontable or to an external file and specified a data link to an Excel spreadsheet
DATALINK :: The Data Link Manager is displayed.
DATALINKUPDATE :: Updates data to or from an established externaldata link.
DBCONNECT :: Providesan interface to external database tables
DBLIST :: Lists database informationfor each object in the drawing
DDEDIT :: Editssingle-line text, dimension text, attribute definitions, and feature controlframes
DDPTYPE :: Specifies the display styleand size of point objects
DDVPOINT :: Sets the three-dimensionalviewing direction
DELAY :: Providesa timed pause within a script
DETACHURL :: Removes hyperlinks in a drawing
DGNADJUST :: Changes the display options of selected DGNunderlays
DGNATTACH :: Attaches a DGN underlay to the currentdrawing
DGNCLIP :: Defines a clipping boundary for a selectedDGN underlay
DGNEXPORT :: Creates one or more V8 DGN files from the currentdrawing
DGNIMPORT :: Imports the data from a V8 DGN file into a newDWG file
DIMandDIM1 :: AccessesDimensioning mode
DIMALIGNED :: Createsan aligned linear dimension
DIMANGULAR :: Creates an angular dimension
DIMARC :: Creates an arc lengthdimension
DIMBASELINE :: Createsa linear, angular, or ordinate dimension from the baseline of the previousdimension or a selected dimension
DIMBREAK :: Adds or removes a dimension break
DIMCENTER :: Createsthe center mark or the centerlines of circles and arcs
DIMCONTINUE :: Createsa linear, angular, or ordinate dimension from the second extension lineof the previous dimension or a selected dimension
DIMDIAMETER :: Createsdiameter dimensions for circles and arcs
DIMDISASSOCIATE :: Removes associativity fromselected dimensions
DIMEDIT :: Editsdimension text and extension lines on dimension objects
DIMINSPECT :: Createor remove inspection dimensions
DIMJOGGED :: Creates jogged radiusdimensions
DIMJOGLINE :: Adds or removes a jog line on a linear or aligneddimension
DIMLINEAR :: Createsa linear dimensions
DIMORDINATE :: Createsordinate point dimensions
DIMOVERRIDE :: Overridesdimensioning system variables
DIMRADIUS :: Createsradial dimensions for circles and arcs
DIMREASSOCIATE :: Associatesselected dimensions to geometric objects
DIMREGEN :: Updates the locationsof all associative dimensions
DIMSPACE :: Adjusts the spacing equally between parallellinear and angular dimensions
DIMSTYLE :: Creates and modifies dimension styles
DIMTEDIT :: Moves and rotates dimension text
DIST :: Measuresthe distance and angle between two points
DISTANTLIGHT :: Creates adistant light
DIVIDE :: Placesevenly spaced point objects or blocks along the length or perimeterof an object
DONUT :: Drawsfilled circles and rings
DRAGMODE :: Controlsthe way dragged objects are displayed
DRAWINGRECOVERY :: Displaysa list of drawing files that can be recovered after a program or systemfailure
DRAWINGRECOVERYHIDE :: Closes the Drawing Recovery Manager
DRAWORDER :: Changes the draw orderof images and other objects
DSETTINGS :: Sets grid and snap, polar and object snaptracking, object snap modes, and Dynamic Input
DSVIEWER :: Opens the Aerial View window
DVIEW :: Defines parallel projectionor perspective views by using a camera and target
DWFADJUST :: Allows adjustment of a DWF underlay at the commandprompt
DWFATTACH :: Attaches a DWF underlay to the currentdrawing
DWFCLIP :: Uses clipping boundaries to define a subregionof a DWF underlay
DWFLAYERS :: Controls the display of layers in a DWF underlay
DWGPROPS :: Sets and displays the properties of the currentdrawing
DXBIN :: Imports speciallycoded binary files
EATTEDIT :: Editsattributes in a block reference
EATTEXT :: Exports property data fromobjects, block attribute information, and drawing information toa table or to an external file
EDGE :: Changesthe visibility of three-dimensional face edges
EDGESURF :: Createsa three-dimensional polygon mesh
ELEV :: Sets elevationand extrusion thickness of new objects
ELLIPSE :: Createsan ellipse or an elliptical arc
ERASE :: Removes objectsfrom a drawing
ETRANSMIT :: Packages a set of files for Internet transmission
EXPLODE :: Breaks a compound objectinto its component objects
EXPORT :: Savesobjects to other file formats
EXPORTTOAUTOCAD :: Creates a new DWG file with all AEC objectsexploded
EXTEND :: Extends an object to meet another object
EXTERNALREFERENCES :: Displaysthe External References palette
EXTERNALREFERENCESCLOSE :: Closesthe External References palette
EXTRUDE :: Createsa 3D solid or surface by extruding an object or planar face a specified distanceand direction
FIELD :: Createsa multiline text object with a field that can be updated automatically asthe field value changes
FILL :: Controlsthe filling of objects such as hatches, two-dimensional solids,and wide polylines
FILLET :: Roundsand fillets the edges of objects
FILTER :: Createsa list of requirements that an object must meet to be included ina selection set
FIND :: Finds,replaces, selects, or zooms to specified text
FLATSHOT :: Createsa 2D representation of all 3D objects in the current view
FOG :: Obsolete
FREESPOT :: Creates a free spotlight,which is similar to a spotlight but without a specified target
FREEWEB :: Creates a free weblightwhich is similar to a weblight but without a specified target
GEOGRAPHICLOCATION :: Specifiesthe latitude and longitude of a location
GOTOURL :: Opens the file or web page associated with thehyperlink attached to an object
GRADIENT :: Fillsan enclosed area or selected objects with a gradient fill
GRAPHSCR :: Switches from the text windowto the drawing area
GRID :: Displays a grid in the current viewport thatis not plotted
GROUP :: Creates and manages saved sets of objectscalled groups
HATCH :: Fills an enclosed area or selected objectswith a hatch pattern, solid fill, or gradient fill
HATCHEDIT :: Modifies an existinghatch or fill
HELIX :: Createsa 2D or 3D spiral
HELP :: DisplaysHelp
HIDE :: Regeneratesa three-dimensional wireframe model with hidden lines suppressed
HLSETTINGS :: Controlsthe display properties of models
HYPERLINK :: Attaches a hyperlink to an object or modifiesan existing hyperlink
HYPERLINKOPTIONS :: Controlsthe display of the hyperlink cursor, tooltips, and shortcut menu
ID :: Displaysthe coordinate of a location
IMAGE :: Displays the External References palette
IMAGEADJUST :: Controlsthe image display of the brightness, contrast, and fade values of images
IMAGEATTACH :: Attachesa new image to the current drawing
IMAGECLIP :: Usesclipping boundaries to define a subregion of an image object
IMAGEFRAME :: Controls whether image frames aredisplayed and plotted
IMAGEQUALITY :: Controls the display quality of images
IMPORT :: Importsfiles in various formats
IMPRINT :: Imprints an edge on a 3D solid
INSERT :: Places a drawing or named block into thecurrent drawing
INSERTOBJ :: Inserts a linked or embedded object
INTERFERE :: Highlights3D solids that overlap
INTERSECT :: Createscomposite solids or regions from the intersection of two or more solidsor regions and removes the areas outside of the intersection
ISOPLANE :: Specifiesthe current isometric plane
JOGSECTION :: Addsa jogged segment to a section object
JOIN :: Joins objects to forma single, unbroken object
JPGOUT :: Saves selected objectsto a file in JPEG file format
JUSTIFYTEXT :: Changesthe justification point of selected text objects without changing theirlocations
LAYCUR :: Changes the layer of selected objects to thecurrent layer
LAYDEL :: Deletesthe layer of a selected object and all objects on the layer, andpurges the layer from the drawing
LAYER :: Manages layers and layer properties
LAYERP :: Undoesthe last change or set of changes made to layer settings
LAYERPMODE :: Turns thetracking of changes made to layer settings on and off
LAYERSTATE :: Saves, restores, and manages named layerstates
LAYFRZ :: Freezes thelayer of selected objects
LAYISO :: Hides orlocks all layers other than those of the selected objects
LAYLCK :: Locksthe layers of selected objects
LAYMCH :: Changesthe layer of a selected object to match the destination layer.
LAYMCUR :: Makes the layer of a selected object current
LAYMRG :: Mergesselected layers onto a destination layer
LAYOFF :: Turns off the layer of the selected object
LAYON :: Turns on all layers
LAYOUT :: Creates and modifies drawing layout tabs
LAYOUTWIZARD :: Createsa new layout tab and specifies page and plot settings
LAYTHW :: Thawsall layers
LAYTRANS :: Changesa drawing's layers to layer standards you specify
LAYULK :: Unlocks the layer of a selected object
LAYUNISO :: Turns on layers that were turned off with thelast LAYISO command
LAYVPI :: Isolates an object's layer to the currentviewport
LAYWALK :: Dynamically displays layers in a drawing
LEADER :: Createsa line that connects annotation to a feature
LENGTHEN :: Changesthe length of objects and the included angle of arcs
LIGHT :: Creates alight
LIGHTLIST :: Opens the Lights in Model window to addand modify lights
LIGHTLISTCLOSE :: Closes the Lights in Model window
LIMITS :: Setsand controls the limits of the grid display in the current Modelor layout tab
LINE :: Createsstraight line segments
LINETYPE :: Loads, sets, and modifies linetypes
LIST :: Displaysdatabase information for selected objects
LIVESECTION :: Turns on live sectioning fora selected section object.
LOAD :: Makesshapes available for use by the SHAPE command
LOFT :: Creates a 3D solid or surface by loftingthrough a set of two or more curves
LOGFILEOFF :: Closes the text window log file openedby LOGFILEON
LOGFILEON :: Writesthe text window contents to a file
LSEDIT :: Has no effect exceptto preserve the integrity of scripts
LSLIB :: Has no effect exceptto preserve the integrity of scripts
LSNEW :: Has no effect exceptto preserve the integrity of scripts
LTSCALE :: Setsthe global linetype scale factor
LWEIGHT :: Setsthe current lineweight, lineweight display options, and lineweightunits
MARKUP :: Displays the details of markups and allows youto change their status
MARKUPCLOSE :: Closes the Markup Set Manager
MASSPROP :: Calculatesthe mass properties of regions or 3D solids
MATCHCELL :: Applies the properties of a selected table cellto other table cells
MATCHPROP :: Appliesthe properties of a selected object to other objects
MATERIALATTACH :: Appliesmaterials to objects by layer
MATERIALMAP :: Displaysa material mapping gizmo to adjust the mapping on a face or an object
MATERIALS :: Manages, applies, and modifies materials
MATERIALSCLOSE :: Closesthe Materials window
MATLIB :: Obsolete
MEASURE :: Placespoint objects or blocks at measured intervals on an object
MENU :: Loadsa customization file
MENULOAD :: Obsolete
MENUUNLOAD :: Obsolete
MINSERT :: Insertsmultiple instances of a block in a rectangular array
MIRROR :: Createsa mirror image copy of objects
MIRROR3D :: Createsa mirror image of objects about a plane
MLEADER :: Creates a line that connects annotation to afeature
MLEADERALIGN :: Organizes selected multileaders along a specifiedline
MLEADERCOLLECT :: Organizes selected multileaders containing blocksas content into a group attached to a single leader line
MLEADEREDIT :: Adds leader lines to, or removes leader linesfrom, a multileader object
MLEADERSTYLE :: Defines a new multileader style
MLEDIT :: Editsmultiline intersections, breaks, and vertices
MLINE :: Creates multipleparallel lines
MLSTYLE :: Creates,modifies, and manages multiline styles
MODEL :: Switchesfrom a layout tab to the Model tab
MOVE :: Movesobjects a specified distance in a specified direction
MREDO :: Reverses the effects of several previous UNDOor U commands
MSLIDE :: Createsa slide file of the current model viewport or the current layout
MSPACE :: Switches from paper space to a model space viewport
MTEDIT :: Edits multiline text
MTEXT :: Creates paragraphs oftext as a single multiline text (mtext) object
MULTIPLE :: Repeatsthe next command until canceled
MVIEW :: Createsand controls layout viewports
MVSETUP :: Sets upthe specifications of a drawing
NETLOAD :: Loadsa .NET application
NEW :: Creates a new drawing
NEWSHEETSET :: Createsa new sheet set
OBJECTSCALE :: Adds or deletes supportedscales for < >
OFFSET :: Creates concentric circles, parallel lines, andparallel curves
OLELINKS :: Updates, changes, and cancels existingOLE links
OLESCALE :: Controls the size, scale, and other propertiesof a selected OLE object
OOPS :: Restoreserased objects
OPEN :: Opens an existing drawing file
OPENDWFMARKUP :: Opens a DWF file that contains markups
OPENSHEETSET :: Opens a selectedsheet set
OPTIONS :: Customizes the program settings
ORTHO :: Constrainscursor movement to the horizontal or vertical direction
OSNAP :: Sets running object snap modes
PAGESETUP :: Controls the page layout,plotting device, paper size, and other settings for each new layout
PAN :: Moves the view in thecurrent viewport
PARTIALOAD :: Loads additional geometry into a partiallyopened drawing
PARTIALOPEN :: Loads geometry and named objects from a selected view or layer into a drawing
PASTEASHYPERLINK :: Inserts data from the Clipboard as a hyperlink
PASTEBLOCK :: Pastes copied objects as a block
PASTECLIP :: Inserts data from the Clipboard
PASTEORIG :: Pastes a copied object in a new drawing usingthe coordinates from the original drawing
PASTESPEC :: Inserts data from the Clipboard and controlsthe format of the data
PCINWIZARD :: Displays a wizard to import PCP and PC2 configurationfile plot settings into the Model tab or current layout
PEDIT :: Editspolylines and three-dimensional polygon meshes
PFACE :: Creates a three-dimensional polyface mesh vertexby vertex
PLAN :: Displays the plan viewof a specified user coordinate system
PLANESURF :: Creates a planar surface
PLINE :: Createstwo-dimensional polylines
PLOT :: Plotsa drawing to a plotter, printer, or file
PLOTSTAMP :: Places a plot stamp on a specifiedcorner of each drawing and logs it to a file
PLOTSTYLE :: Sets the current plot style for new objectsor assigns a plot style to selected objects
PLOTTERMANAGER :: Displays the Plotter Manager, where you canadd or edit a plotter configuration
PNGOUT :: Saves selected objectsto a file in a Portable Network Graphics format
POINT :: Createsa point object
POINTLIGHT :: Creates a point light
POLYGON :: Createsan equilateral closed polyline
POLYSOLID :: Creates a 3D polysolid
PRESSPULL :: Presses or pulls bounded areas
PREVIEW :: Shows how the drawingwill look when it is plotted
PROPERTIES :: Controlsproperties of existing objects
PROPERTIESCLOSE :: Closesthe Properties palette
PSETUPIN :: Imports a user-defined pagesetup into a new drawing layout
PSPACE :: Switches from a model space viewport to paperspace
PUBLISH :: Publishesdrawings to DWF files or plotters
PUBLISHTOWEB :: Creates HTML pages that include images of selected drawings
PURGE :: Removes unused named items, such as block definitions and layers, from the drawing
PYRAMID :: Creates a 3D solid pyramid
QCCLOSE :: Closes QuickCalc
QDIM :: Quicklycreates a dimension
QLEADER :: Createsa leader and leader annotation
QNEW :: Starts a new drawingwith the option of using a default drawing template file
QSAVE :: Savesthe current drawing using the file format specified in the Options dialogbox
QSELECT :: Createsa selection set based on filtering criteria
QTEXT :: Controls the display and plotting of text andattribute objects
QUICKCALC :: Opens the QuickCalc calculator
QUICKCUI :: Displays the CustomizeUser Interface dialog box in a collapsed state
QUIT :: Exits the program
RAY :: Createsa semi-infinite line
RECOVER :: Repairs a damaged drawing
RECOVERALL :: Repairs a damaged drawing and xrefs
RECTANG :: Drawsa rectangular polyline
REDEFINE :: Restores AutoCAD internal commands overriddenby UNDEFINE
REDO :: Reverses the effectsof previous UNDO or U command
REDRAW :: Refreshesthe display in the current viewport
REDRAWALL :: Refreshesthe display in all viewports
REFCLOSE :: Savesback or discards changes made during in-place editing of a reference (anxref or a block)
REFEDIT :: Selectsan external reference or block reference for editing
REFSET :: Adds or removes objectsfrom a working set during in-place editing of a reference (an xrefor a block)
REGEN :: Regeneratesthe entire drawing from the current viewport
REGENALL :: Regenerates the drawingand refreshes all viewports
REGENAUTO :: Controlsautomatic regeneration of a drawing
REGION :: Converts an object thatencloses an area into a region object
REINIT :: Reinitializes thedigitizer, digitizer input/output port, and program parameters file
RENAME :: Changes the names of named objects
RENDER :: Creates aphotorealistic or realistically shaded image of a three-dimensional wireframeor solid model
RENDERCROP :: Selects a specific region (crop window) in animage for rendering
RENDERENVIRONMENT :: Provides visualcues for the apparent distance of objects
RENDEREXPOSURE :: Provides settings to interactively adjustthe global lighting for the most recent rendered output
RENDERPRESETS :: Specifiesrender presets, reusable rendering parameters, for rendering an image
RENDERWIN :: Displays the Render Windowwithout invoking a render task
RENDSCR :: Obsolete
REPLAY :: Obsolete
RESETBLOCK :: Resetsone or more dynamic block references to the default values of the blockdefinition
RESUME :: Continuesan interrupted script
REVCLOUD :: Creates a polyline ofsequential arcs to form a cloud shape
REVOLVE :: Createsa 3D solid or surface by revolving 2D objects about an axis
REVSURF :: Createsa revolved mesh about a selected axis
RMAT :: Obsolete
ROTATE :: Revolvesobjects around a base point
ROTATE3D :: Movesobjects about a three-dimensional axis
RPREF :: Displays theAdvanced Render Settings palette for access to advanced renderingsettings
RPREFCLOSE :: Closes the Render Settings palette if it isdisplayed
RSCRIPT :: Repeatsa script file
RULESURF :: Createsa ruled mesh between two curves
SAVE :: Savesthe drawing under the current file name or a specified name
SAVEAS :: Savesa copy of the current drawing under a new file name
SAVEIMG :: Saves arendered image to a file
SCALE :: Enlargesor reduces selected objects proportionally in the X, Y,and Z directions
SCALELISTEDIT :: Controls the list of scales available for layoutviewports, page layouts, and plotting
SCALETEXT :: Enlargesor reduces selected text objects without changing their locations
SCRIPT :: Executesa sequence of commands from a script file
SECTION :: Usesthe intersection of a plane and solids to create a region
SECTIONPLANE :: Createsa section object that acts as a cutting plane through a 3D object
SECURITYOPTIONS :: Controlssecurity settings using the Security Options dialog box
SELECT :: Placesselected objects in the Previous selection set
SETBYLAYER :: Changes property and ByBlock settings for selectedobjects to ByLayer
SETIDROPHANDLER :: Specifiesthe default type of i-drop content for the current Autodesk application
SETUV :: Obsolete
SETVAR :: Listsor changes the values of system variables
SHADEMODE :: Startsthe VSCURRENT command
SHAPE :: Inserts ashape from a shape file that has been loaded using LOAD
SHEETSET :: Opens theSheet Set Manager
SHEETSETHIDE :: Closesthe Sheet Set Manager
SHELL :: Accesses operating system commands
SHOWMAT :: Obsolete
SIGVALIDATE :: Displays informationabout the digital signature attached to a file
SKETCH :: Createsa series of freehand line segments
SLICE :: Slices a solidwith a plane or surface
SNAP :: Restrictscursor movement to specified intervals
SOLDRAW :: Generatesprofiles and sections in viewports created with SOLVIEW
SOLID :: Createssolid-filled triangles and quadrilaterals
SOLIDEDIT :: Editsfaces and edges of 3D solid objects
SOLPROF :: Creates profileimages of three-dimensional solids in paper space
SOLVIEW :: Createslayout viewports using orthographic projection to lay out multi-and sectional view drawings of 3D solids and body objects
SPACETRANS :: Calculates equivalentmodel space and paper space lengths in a layout
SPELL :: Checks spelling in a drawing
SPHERE :: Createsa 3D solid sphere
SPLINE :: Fits a smooth curve to a sequenceof points within a specified tolerance
SPLINEDIT :: Edits a spline or spline-fit polyline
SPOTLIGHT :: Createsa spotlight
STANDARDS :: Managesthe association of standards files with drawings.
STATUS :: Displaysdrawing statistics, modes, and extents
STLOUT :: Storesa solid in an ASCII or binary file
STRETCH :: Movesor stretches the objects
STYLE :: Creates, modifies, or sets named textstyles
STYLESMANAGER :: Displaysthe Plot Style Manager
SUBTRACT :: Combines selected regionsor solids by subtraction
SUNPROPERTIES :: Opensthe Sun Properties window and sets the properties of the sun
SUNPROPERTIESCLOSE :: Closesthe Sun Properties window
SWEEP :: Creates a 3D solid or surface by sweeping a2D curve along a path
SYSWINDOWS :: Arrangeswindows and icons when the application window is shared with externalapplications
TABLE :: Creates an empty tableobject in a drawing
TABLEDIT :: Editstext in a table cell
TABLEEXPORT :: Exports data from a tableobject in CSV file format
TABLESTYLE :: Defines a new table style
TABLET :: Calibrates, configures, and turns on andoff an attached digitizing tablet
TABSURF :: Creates a tabulated mesh from a path curveand a direction vector
TARGETPOINT :: Creates a target pointlight
TASKBAR :: Controls how drawings are displayed on the Windowstaskbar
TEXT :: Creates a single-line text object
TEXTSCR :: Opens the text window
TEXTTOFRONT :: Bringstext and dimensions in front of all other objects in the drawing
THICKEN :: Creates a 3D solid by thickening a surface
TIFOUT :: Saves selected objectsto a file in TIFF file format
TIME :: Displaysthe date and time statistics of a drawing
TINSERT :: Inserts a block in atable cell
TOLERANCE :: Creates geometric tolerances
TOOLBAR :: Displays,hides, and customizes toolbars
TOOLPALETTES :: Opensthe Tool Palettes window
TOOLPALETTESCLOSE :: Closesthe Tool Palettes window
TORUS :: Creates a 3D donut-shaped solid
TPNAVIGATE :: Displays a specified tool palette or palettegroup
TRACE :: Createssolid lines
TRANSPARENCY :: Controlswhether background pixels in a bitonal image are transparent or opaque
TRAYSETTINGS :: Controlsthe display of icons and notifications in the status bar tray
TREESTAT :: Displays information about the drawing'scurrent spatial index
TRIM :: Trims objects at a cutting edge defined by otherobjects
U :: Reversesthe most recent operation
UCS :: Managesuser coordinate systems
UCSICON :: Controls the visibility and placement of theUCS icon
UCSMAN :: Manages defined user coordinate systems
UNDEFINE :: Allowsan application-defined command to override an internal command
UNDO :: Reverses the effect of commands
UNION :: Combinesselected regions or solids by addition
UNITS :: Controlscoordinate and angle display formats and precision
UPDATEFIELD :: Manuallyupdates fields in selected objects in the drawing
UPDATETHUMBSNOW :: Manuallyupdates thumbnail previews for sheets, sheet views, and model spaceviews in the Sheet Set Manager
VBAIDE :: Displaysthe Visual Basic Editor
VBALOAD :: Loads a globalVBA project into the current work session
VBAMAN :: Loads, unloads, saves, creates, embeds, andextracts VBA projects
VBARUN :: Runs a VBA macro
VBASTMT :: Executesa VBA statement on the AutoCAD command line
VBAUNLOAD :: Unloadsa global VBA project
VIEW :: Savesand restores named views, camera views, layout views, and preset views
VIEWPLOTDETAILS :: Displaysinformation about completed plot and publish jobs
VIEWRES :: Sets the resolutionfor objects in the current viewport
VISUALSTYLES :: Createsand modifies visual styles and applies a visual style to a viewport
VISUALSTYLESCLOSE :: Closesthe Visual Styles Manager
VLISP :: Displays the Visual LISP interactive developmentenvironment (IDE)
VPCLIP :: Clipsviewport objects and reshapes the viewport border
VPLAYER :: Setslayer visibility within viewports
VPMAX :: Expands the current layout viewport for editing
VPMIN :: Restores the current layout viewport
VPOINT :: Sets the viewing direction fora three-dimensional visualization of the drawing
VPORTS :: Creates multiple viewports in model spaceor paper space
VSCURRENT :: Sets the visual style in the current viewport
VSLIDE :: Displays an image slide file in thecurrent viewport
VSSAVE :: Saves a visual style
VTOPTIONS :: Displays a change inview as a smooth transition
WALKFLYSETTINGS :: Specifies walk and fly settings
WBLOCK :: Writesobjects or a block to a new drawing file
WEBLIGHT :: Creates a web light
WEDGE :: Createsa five-sided 3D solid with a sloped face tapering along the X axis
WHOHAS :: Displays ownership informationfor opened drawing files
WIPEOUT :: Covers existing objectswith a blank area
WMFIN :: Importsa Windows metafile
WMFOPTS :: Sets options for WMFIN
WMFOUT :: Saves objects to a Windowsmetafile
WORKSPACE :: Creates,modifies, and saves workspaces and makes a workspace current
WSSAVE :: Savesa workspace
WSSETTINGS :: Setsoptions for workspaces
XATTACH :: Attaches an externalreference to the current drawing
XBIND :: Bindsone or more definitions of named objects in an xref to the current drawing
XCLIP :: Defines anxref or block clipping boundary and sets the front and back clippingplanes
XEDGES :: Creates wireframe geometry by extracting edgesfrom a 3D solid or surface
XLINE :: Createsan infinite line
XOPEN :: Opensa selected drawing reference (xref) in a new window
XPLODE :: Breaksa compound object into its component objects
XREF :: Starts the EXTERNALREFERENCES command
ZOOM :: Increases or decreases the apparent size ofobjects in the current viewport
rgds
Dilip Damle
Life will be much easier if we just have a printout of
all the commands that exist in Autocad kept handy.
Announcements
Need installation help?
