On the right hand side is an image of the default spacing I get between X ref's and graphic for switch contact.
Does anyone know if its possible to alter the spacing so its more like the left hand image rather than the right?
Many thanks, Will.
Hi, I've attached a .dwg.
In the bottom right of the screen are some x references, these are the default format.
As you can see they are somewhat misleading because of the spacing between graphic and x reference. If there is a full line of coils all with multiple NC/NO contacts it gets quite messy.
thanks, W.
I have checked attached file and still couldn't understand what's going wrong. The only thing it may affect the spacing in your text is that there are 3 spaces instead of 1 space at concerned position. Just use FIND to replace all 3 spaces " " with 1 space " ". The result is as below:
