AutoCAD 2007/2008/2009
Member
MEARLY
Message 1 of 1 (79 Views)
Data Connect XRefs
79 Views, 0 Replies
04-01-2009 01:02 PM
Hello all,
I'm running Map09 with Carlson civil 09 add on, I've got an issue with .sid images.
I've loaded my images through "Data Connect" in the task pane and they show on the screen, but under the xref manager they show as unreferenced and show as linked to my c:temp folder. When this dwg is xrefed into another dwg the images do not show at all. I'm trying to set this up as a base dwg with arial photos to xref into multiple dwgs in the project instead of inserting all of the photos into the dwgs separately.
Thank you,
