AutoCAD 2007/2008/2009
Member
0 Kudos
Post 1 of 15
Customization File Load Error
3686 Views, 14 Replies
11-06-2007 03:28 PM
When I start my AutoCad I get the error:
Customization file load failed. File not found: C\Documents and Settings\ arrudan1\Application Data\Adobe\Acrobat\8.0\ACAD-5001-409\PDFIC.cui
After this error AutoCAD starts but there are no toolbars except the Acrobat one.
I went to my school's tech center, my computer is school issued and AutoCad is licensed to the school, they reinstalled the program and it started fine there. But when I started it the next time the same error came up. Does anyone know what I can do?
*Gehenna
Post 2 of 15
Re: Customization File Load Error
11-06-2007 03:53 PM in reply to: Nicholas482109
The second line of your post tells you the problem: C\Documents and
I believe this means the PDFIC.cui is located in a location other than
were it should be and autocad can't find it because this location is not
in your search file path. Add the location to your search file.
Member
0 Kudos
Post 3 of 15
11-06-2007 05:02 PM in reply to: Nicholas482109
I searched for PDFIC.cui on my hard drive and nothing came up. I looked at the directory the error came from and there was no ACAD-5001-409 folder, I searched for that folder and it came up under the location C\Documents and Settings\arrudan1\Application Data\Adobe\Acrobat\8.0.
The folder will not open though, an error message saying "C\Documents and Settings\ arrudan1\Application Data\Adobe\Acrobat\8.0\ACAD-5001-409\ refers to a location that is unavailable"
*Gehenna
Post 4 of 15
11-06-2007 05:10 PM in reply to: Nicholas482109
You will need the pdfic.cui from your school and put it in your Support
folder. Otherwise, it will have to be burried deep in Document and
Settings\etc\etc\etc . . . . Totally worthless to go through. Just put
it in the Support folder and you should be alright.
Member
0 Kudos
Post 5 of 15
11-06-2007 07:57 PM in reply to: Nicholas482109
The installation was a repair install done over the network by the people at the tech center, should i ask them to just uninstall then reinstall the program?
*Gehenna
Post 6 of 15
11-06-2007 08:08 PM in reply to: Nicholas482109
I don't think that would work any better. I don't understand the cui -
it should be acad.cui, however, it appears to be applicable to your tech
center. You just need that cui copied to a flash drive and then copied
to the Support folder in autocad. While having the cui in the support
folder is not where autocad normally puts it during installation,
nothing wrong; I have mine there and whenever I need to load it via
menuload, that's where I browse for it and my system has been working
well since I got it in May.
Member
0 Kudos
Post 7 of 15
11-07-2007 10:51 AM in reply to: Nicholas482109
I searched for acad.cui and found several, one for each of the Autodesk programs on my computer. I also searched on another student's computer for the PDFIC.cui file and nothing came up, the ACAD-5001-409 folder appeared in search the same way as it did for me. could this be a problem with adobe acrobat?
*Gehenna
Post 8 of 15
11-07-2007 12:46 PM in reply to: Nicholas482109
Possible. I would delete the entire folder, i.e., in C\Documents and
Data\Adobe\Acrobat\8.0\ACAD-5001-409\PDFIC.cui. Go to My Computer, then
Document and Settings and delete arrudan1\application, etc. (what a
mess). Be careful: notice there is a SPACE immediately before arrudan1.
I don't understand how Adobe Acrobat could be causing this, but I would
start by deleting as noted above and getting autocad running correctly.
Then, you may have to re-install Acrobat (why have it in autocad?).
Member
0 Kudos
Post 9 of 15
11-08-2007 09:15 AM in reply to: Nicholas482109
I deleted the folder and re-installed Acrobat, with no change. Any other ideas before I think going to the tech center and let them have at my computer?
The weirdest part about this problem is that i can still use all the auto cad commands, I can even open the User Customization Interface where i can access the cui files, can i do anything in here?
Message was edited by: Nicholas482109 Message was edited by: Nicholas482109
New Member
0 Kudos
Post 10 of 15
06-15-2008 01:11 AM in reply to: Nicholas482109
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
