AutoCAD 2007/2008/2009
Active Contributor
j.mcmahan
Message 1 of 11 (247 Views)
Custom Field?
247 Views, 10 Replies
04-03-2009 06:20 AM
Is it possible to create a custom field? One that's not listed.
*Dean Saadallah
Message 2 of 11 (247 Views)
Re: Custom Field?
04-03-2009 06:54 AM in reply to: j.mcmahan
FIELD>Diesel Expression or Objects, depends on your intent: your post is not
clear
Dean Saadallah
http://LTisACAD.blogspot.com
Active Contributor
j.mcmahan
Message 3 of 11 (247 Views)
Re: Custom Field?
04-03-2009 07:17 AM in reply to: j.mcmahan
You're right, it's a little unclear. However, I think your answer will help formulate a better question. When creating a field, what is the syntax of a diesel expression I could write that will list xrefs associated with a drawings. I can use Attached Xrefs: $(xrefs,8,,:smileywink: with RTEXT, but when I try that or just $(xrefs,8,,:smileywink: when making a field with diesel, it says that the function is not valid. Any ideas? I really need it as a field.
*Tim Decker
Message 4 of 11 (247 Views)
Re: Custom Field?
04-03-2009 07:35 AM in reply to: j.mcmahan
There are locally defined DIESEL expressions exclusive to
RTEXT; $(getprop), $(xrefs), $(images), & $(getrec).  These are
not evaluated by a regular DIESEL interpreter.
Active Contributor
j.mcmahan
Message 5 of 11 (247 Views)
Re: Custom Field?
04-03-2009 07:37 AM in reply to: j.mcmahan
Am I out of luck then with the field I want to create?
*Tim Decker
Message 6 of 11 (247 Views)
Re: Custom Field?
04-03-2009 07:46 AM in reply to: j.mcmahan
If the field you want relies on those RTEXT expressions.
I can’t remember if you can call LISP from a DIESEL expression or not, but if
you can, you could insert the LISP code to do the
job.
*Dean Saadallah
Message 7 of 11 (247 Views)
Re: Custom Field?
04-03-2009 08:39 AM in reply to: j.mcmahan
FIELD>Objects Category>Object>... at the Object Type, use the button to
select the Xref is one way.
Dean Saadallah
Member
MOABI%20
Message 8 of 11 (247 Views)
Re: Custom Field in a Custom Entity?
06-04-2009 09:43 PM in reply to: j.mcmahan
Hey, is it possible to add custom data (e.g. a simple C++ class/object called Banana) to a custom entity i.e. Monkey which derives from AcDbEntity and is located in a DBX module.
Banana- object holds banana properties like : colour, length, weight e.t.c
Monkey -is an AcDbEntity derived object that displays a drawing of a Monkey holding the banana.
Distinguished Contributor
keithc03
Message 9 of 11 (247 Views)
Re: Custom Field?
06-05-2009 04:14 AM in reply to: j.mcmahan
If you go to the FILE menu and DRAWING PROPERTIES you can create a custom properties there and see them in them in the fields listing
keithc03
Message 10 of 11 (247 Views)
Re: Custom Field?
06-05-2009 04:17 AM in reply to: j.mcmahan
WHATS NO CLEAR ABOUT "Is it possible to create a custom field? One that's not listed."
they want to create a custom (user defined field )
Announcements
Need installation help?
