AutoCAD 2007/2008/2009
Active Member
0 Kudos
Post 1 of 4
Cover Sheet
100 Views, 3 Replies
07-31-2008 09:16 AM
Is there a SIMPLE (I know, I'm in the wrong forum) way to "cut and paste" file names as displayed by Windows into a .DWG file.?
I'm trying to make a cover sheet that will display all the drawing file names without have to retype them all.
I've pulled EXCEL spreadsheets into drawings with some success previously.
*Jason Piercey
Post 2 of 4
Re: Cover Sheet
07-31-2008 09:21 AM in reply to: paryk
You could use a DOS prompt to get names into a .txt file
then cut/paste from there.
At a dos prompt, after changing to the directory you want, type:
dir *.dwg /b > dwgs.txt
Open that dwgs.txt file and cut/paste.
wrote in message news:5995374@discussion.autodesk.com...
Distinguished Contributor
1 Kudo
Post 3 of 4
Re: Cover Sheet
07-31-2008 09:23 AM in reply to: paryk
What you need is called Windows Powertoy Program
after select the files you can Send to as names to a clip board and it can be imported to acad.
2 Kudos
Post 4 of 4
Re: Cover Sheet
07-31-2008 10:46 AM in reply to: paryk
The combination of the previous two posts:
DIR *.DWG /b | Clip
Clip.exe (attached as a zip) is a MS freebie.
It goes in C:\WINDOWS\system32.
Just a copy, no "install".
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
