Hellow Everyone,
Could you please help me with something
I need to fiind a way to copy part of polyline when the polyline intersect with a rectangle.Put that part of the polylines in separate layout.
But doing this thru autocad 2008 vba macro
A know there is something with getboundingbox and interechwith.
Thankyou so much for your help
The pictures above shows what i want
You should then ask in the forum for AutoCAD >>>Visual Basic Customization<<<
To start: first calculate the intersection points between the rectangle the the polyline, then check which parts of the polyline segments are inside the rectangle, which segments are crossing the rectangle and which segments are outside the rectangle. And now create the new polylines based on the inner ones + the crossing segments up to the intersection point.
Good luck, - alfred -
Thankyou so much for your hint.
I will try stept by step to get done all of this measurments
Thankyou again for all your help
