AutoCAD 2007/2008/2009
Active Member
javier_glez
Message 1 of 5 (632 Views)
copy block definition and assign
632 Views, 4 Replies
12-21-2006 10:30 AM
Hi, what happened with this feature?? I can´t find it in autocad 2007. Is there any way to enable it? Thanks in advance.
*Dean Saadallah
Message 2 of 5 (632 Views)
Re: copy block definition and assign
12-21-2006 11:56 AM in reply to: javier_glez
What's the actual command called? Or if you don't remember,
where exactly did you pick it from in a menu?
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Active Member
javier_glez
Message 3 of 5 (632 Views)
12-21-2006 12:06 PM in reply to: javier_glez
the command line was in autocad 2005 :CopyBlockDefAndAssign
you coluld pick it from the shortcut menu in drawing area when a block was selected.
This command did a useful thing, copy a block, rename it and then let you modified it. at the end of proccess you get 2 blocks: the original and a new one that come from the first.
thank you so much and sorry for my english
*Dean Saadallah
Message 4 of 5 (632 Views)
12-21-2006 01:17 PM in reply to: javier_glez
Your English is fine my friend.
No such command in any plain AutoCAD version, 2005 or 2007
or anything in between or before: perhaps you had an add-on,
or a customization that you did not copy over?
HELP in AutoCAD shows you all the core commands available.
Dean Saadallah
*Leo the Builder
Message 5 of 5 (632 Views)
12-21-2006 02:22 PM in reply to: javier_glez
Why not use the BE (Block Edit) command, select the block in question,
save the block with a new name, and edit away...
Leo
wrote in message news:5433156@discussion.autodesk.com...
Announcements
Need installation help?
