I need I need the coordinates automatically appear in my sheets autocad .. how can I do? ... the coordinates of the midpoints of the sheet ... thanks
Hello
Welcome to the Autodesk/AutoCAD Forums !
Please could you explain a liitle bit more ?
Do you want to get for example a Leader with XY coords or XYZ coords somewhere on your DWG ?
Bye, Pat
Patrice BRAUD
Hello from France
Please try this OLD Lisp routine ...
You must load the routine with APPLOAD
Commands : XY or XYZ
PS1: if you need more decimals, let me know !?
PS2: routine has been updated
Bye, Pat
Patrice BRAUD
Hello
If you need more decimals, please change the 2 + 3 lines with the RTOS function :
; With 3 decimals
; (setq pt1x (strcat "X: " (rtos totox 2 3)))
; With 4 decimals
; (setq pt1x (strcat "X: " (rtos totox 2 4)))
Bye, Pat
Patrice BRAUD
