AutoCAD 2007/2008/2009
Active Contributor
kvaughn
Message 1 of 7 (6,666 Views)
Converting .PLT files to .PDF format
6666 Views, 6 Replies
12-21-2009 09:43 AM
Is there a way to take existing .plt files and convert them into .pdf, .eps, .dwf's, .tif, .gif, or any other format.
I have hundreds of existing .plt files that need to be converted over so that the print shop can read them. Our print driver is incompatible to what they are using.
Even if I have to download an outside program that will be o.k.
Edited by: kvaughn on Dec 21, 2009 11:43 AM Edited by: kvaughn on Dec 21, 2009 11:44 AM
*Glenn White
Message 2 of 7 (6,666 Views)
Re: Converting .PLT files to .PDF format
12-21-2009 11:06 AM in reply to: kvaughn
try 'plt to pdf' google - there seems to be a bunch of stuff
wrote in message news:6307885@discussion.autodesk.com...
they are using.
Active Contributor
kvaughn
Message 3 of 7 (6,666 Views)
12-21-2009 11:09 AM in reply to: kvaughn
yeah i tried that glenn and can only find free converters that will convert one at a time or (5) at a time.
I really need to narrow my search to something that can convert all hundred at once if possible.
*Glenn White
Message 4 of 7 (6,666 Views)
12-21-2009 01:12 PM in reply to: kvaughn
ah, I see - that is probably going to be a tough one. Good luck.
wrote in message news:6307899@discussion.autodesk.com...
*Govert J. Knopper
Message 5 of 7 (6,666 Views)
12-24-2009 04:52 AM in reply to: kvaughn
What you did not mention is what file format these ".PLT files" are; ".PLT"
is not a file format; it's only a filename extension. But, as these are
archived files, the format that was chosen is probably a common format like
HPGL(2), in which case I don't see why a decent plotservice would not be
able to plot them directly.
With any conversion there is a risk that you loose information or quality;
having said that, ViewCompanion (http://www.softwarecompanions.com) can
convert HPGL(2) files to the other formats that you mentioned..
Govert
http://www.noliturbare.com
Member
dkaldy
Message 6 of 7 (4,281 Views)
06-11-2013 08:26 AM in reply to: kvaughn
I use a program called equivaQ 2002 to convert .plt files to .pdf.  They have a batch export function... which is very helpful.
*Expert Elite*
rkmcswain
Message 7 of 7 (4,000 Views)
07-03-2013 02:24 PM in reply to: kvaughn
You need a program that can read your PLT files (no matter what the actual file format is), and a program that can print to PDF.
We do it here all the time using Oce Repro Desk to read the PLT files and CutePDF to write the PDF files.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
