AutoCAD 2007/2008/2009
Active Contributor
DevinCurrie
Message 1 of 5 (1,750 Views)
Convert isometric to orthographic view
1750 Views, 4 Replies
02-28-2011 12:18 PM
Hello, I have an illustration of a 3D object on paper.
I'd like to create a reasonably accurate orthographic view out of it by scanning/tracing (the isometric view) in AutoCAD and then convert it to 2D.
Is there a solution that will take care of this?
Devin
Distinguished Mentor
jaich
Message 2 of 5 (1,742 Views)
Re: Convert isometric to orthographic view
02-28-2011 04:13 PM in reply to: DevinCurrie
If reasonably accurate is all you're after, scan it and trace it.  If it is a true iso, only your true length lines will be, well, true length.  There is no magic make orthographic button that I am aware of.
Active Contributor
DevinCurrie
Message 3 of 5 (1,737 Views)
02-28-2011 06:36 PM in reply to: DevinCurrie
Yes lines are easy but how can we deal with curved or irregular-shaped objects? Thanks.
*Pro
Modman_4
Message 4 of 5 (1,709 Views)
03-01-2011 09:13 AM in reply to: DevinCurrie
The ants are my friends, they're blowin' in the wind....
OP you have to draw it from scratch, plain an simple. Are there any dimensions indicated on that paper?
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
*Expert Elite*
JGerth
Message 5 of 5 (1,705 Views)
03-01-2011 11:38 AM in reply to: DevinCurrie
it's called 'drafting' but not in the NASCAR sense of the word.  It's a smidgen more fun here, because instead of trying to represent a 3d object in 2d ortho views, you're taking a 2d isometric, mentally converting that to a 3d object, and then using drafting techniques to generate the ortho views.  do you happen to know if it's an isometric drawing, or an isometric projection?  it will make a difference in the real vs apparent lengths of the non-vertical lines.
Announcements
Need installation help?
