AutoCAD 2007/2008/2009
Member
motiv8j
Message 1 of 8 (13,242 Views)
Convert IGS or Step to DWG
13242 Views, 7 Replies
08-06-2012 08:13 AM
How do you convert IGES or STEP to DWG?
I have IGES of one model and IGES and STEP of another.
My 3D skills are basic, so I want to transfer them to 2D in AutoCAD then dimension.
I recall SOLPROF can be used on a 3D model to give 2D views. Can you tell I haven't used ACAD in anger for a while?
I have Inventor 7 and ACAD 2009.
Thanks in advance,
J.
JDMather
Message 2 of 8 (13,236 Views)
Re: Convert IGS or Step to DWG
08-06-2012 11:38 AM in reply to: motiv8j
You can do the conversion in Inventor or free Inventor Fusion http://labs.autodesk.com or in AutoCAD 2013.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
motiv8j
Message 3 of 8 (13,222 Views)
08-07-2012 03:12 AM in reply to: motiv8j
nightmare!:smileyfrustrated:
I downloaded Inventor Fusion. Only seemed to give me a DWG option, not version related.
I then tried to open the DWG in my AutoCAD 2009. Couldn't do it, needed to download TrueView.
I downloaded TrueView 2011, following the links from AutoCAD 2009. Tried to open the file, said "The file could not be opened as it was created with a more recent version of DWG TrueView.
JDMather
Message 4 of 8 (13,216 Views)
08-07-2012 05:43 AM in reply to: motiv8j
Isn't there a more recent free release of TrueView (2013?) for converting files?
What about saving as 2010 dwg to convert in TrueView 2011?
What about saving as ACIS (*.sat) or *.dxf directly and then opening directly in AutoCAD 2009?
JDMather
Message 5 of 8 (13,212 Views)
08-07-2012 05:49 AM in reply to: motiv8j
Is this the same link that AutoCAD 2009 sent you to?
http://lmgtfy.com/?q=dwg+true+view+2013
JDMather
Message 6 of 8 (13,211 Views)
08-07-2012 05:52 AM in reply to: motiv8j
What about using Inventor 7 and saving as dwg solid?
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
JDMather
Message 7 of 8 (13,208 Views)
08-07-2012 05:55 AM in reply to: JDMather
How about posting your files here
http://forums.autodesk.com/t5/AutoCAD-2013/bd-p/706
or here
http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
and asking someone to do the conversion to 2007 format for you?
That solution would require almost zero effort.
Sleep well, sweet dreams.
Member
motiv8j
Message 8 of 8 (13,204 Views)
08-07-2012 06:12 AM in reply to: motiv8j
So many options :smileysurprised:
I'll try them and let you know which one is the easiest to execute.
Thanks in advance,
J.
